Anyone using a Fox ...
[Closed] Anyone using a Fox CTD Kashima shock?
[#4313730]
Basically I'm looking at two identical frames, one fitted with an RP23 Kashima shock and the other with the new Fox CTD Kashima.
Is anyone running the new CTD that can recommend one as a better damper than the other or are both as good?
As far as I understand the CTD is easier to setup and adjust?
Pointers appreciated folks
Posted : 31/08/2012 10:49 am
No one using these shocks yet?
Posted : 31/08/2012 6:53 pm
I have the new CTD Kashima shock on my bike, Just set up the sag and what ever rebound you need and away you go. As well as the climb trail decent settings you also have a setting for soft medium and stiff.
I cant really give you much more info that that as i've only had it a week now.
Posted : 31/08/2012 7:34 pm
In a nutshell does the CTD settings mean... Stiff-bit softer-soft?
Does the RP23 have similar easy adjustments or is it a case of getting the air pressure more dialled?
Posted : 31/08/2012 7:52 pm
I've got one, yeah it's like you say Danny...soft, medium and stiff.....it was easy to get dialled in and does the job well, I'm happy with it!!
Posted : 01/09/2012 9:51 am
