Does this look like...
[Closed] Does this look like a crack starting at the headtube?
At the base of the weld
http://www.flickr.com/photos/cressbrook/3976066013/sizes/l/
Posted : 03/10/2009 11:13 am
Is that a cannondale..... ๐Ÿ˜›
Posted : 03/10/2009 11:22 am
yup!
Posted : 03/10/2009 11:23 am
Looks more like a scratch, If it was a crack it'd be bigger than that IMO even if it was starting
Posted : 03/10/2009 11:28 am
weird place for a scratch tho and also on he edge of a weld ๐Ÿ™
Posted : 03/10/2009 11:30 am
Difficult to say. I'd say scratch, though it is an unusual place.
Get a permanent marker and put a clear line at each end of it and see if it grows
Posted : 03/10/2009 11:33 am
I will do that and also measure it
thats not a crack
Posted : 03/10/2009 12:12 pm
what length forks are you running, have you exceeded the length on the warning sticker?
Posted : 03/10/2009 12:16 pm
 jedi
yep
Posted : 03/10/2009 12:29 pm
what jedi said
Posted : 03/10/2009 12:31 pm
Looks like a crack to me, sorry. I'm no expert though.
Posted : 03/10/2009 12:38 pm
I'll buy your vanilla r off you.
Oops, sorry...
Posted : 03/10/2009 12:39 pm
running 140mm forks
Posted : 03/10/2009 1:18 pm
Which bike as a matter of interest?
prophet
Posted : 03/10/2009 1:22 pm
it doesn't look like a crack to me n i'm a welder
Posted : 03/10/2009 2:08 pm
Yep. Fubared Rob - send it to me to make sure it is disposed of properly ๐Ÿ˜‰
Congrats by the way! ๐Ÿ˜€
Posted : 03/10/2009 2:14 pm
it looks like a crack to me from where i'm sittin'
Posted : 03/10/2009 2:15 pm
worry about it when you're picking your teeth off the floor ๐Ÿ˜›
Posted : 03/10/2009 2:22 pm
 hora
It does look like a crack to me and Im the Chaiman of the Master Welder's Association.
Posted : 03/10/2009 2:39 pm
you are Chairman Mwa?
suits you
Posted : 03/10/2009 2:46 pm
 Amos
I could get the NDT guy at work to check it for you using eddy current if you're ever in the Reading area, but seeing as you're in the Peak Distict unlikely!
TCut has removed a flake of paint - no crack ๐Ÿ™‚
Posted : 03/10/2009 3:41 pm
 hora
Chairman Mwa?
Ex sadly. I've had to resign due to my assumption on the above picture being incorrect ๐Ÿ˜
Posted : 03/10/2009 5:30 pm
didn't think so mate.you sometimes get a tiny groove between the weld and metal when the welds a little to hot and that can catch dirt.
Posted : 04/10/2009 5:52 am
Easier to use Ardrox spray penetrant and developer. Most welding shops should have a can or two lying around. It'll show whether or not its a crack and how severe it is.
Posted : 04/10/2009 11:05 am
How does it work?
Posted : 04/10/2009 11:11 am
You spray the penetrant on and leave to soak for a few minutes, clean off the excess then spray on the developer. If it is a crack it will show up as (usually) a red line in the developer. The deeper the crack the thicker the line. It's used for checking critical welds on pressure vessels and aero structures. Better for surface cracks than ultra sound.
Posted : 04/10/2009 11:15 am
Sounds good - jontawn is a welder so hopefully he can help me ๐Ÿ™‚
Posted : 04/10/2009 11:32 am
If it ends up like this yer ****ed!...I dont think its a major crack though,looks like a slight flaw in the tube to me,Its not a stressed part of the frame either so nothing strength wise to worry about. ๐Ÿ˜€
Posted : 04/10/2009 12:27 pm
