Does the santa cruz...
[Closed] Does the santa cruz tallboy still suffer the 'circle of death'?
Morning all. I'm looking into purchasing a second hand tallboy Ltc. I have been reading about the above problem. I also read that they started to make the lower link 'square shaped' to avoid this problem. Is this true and if so on what year?
Posted : 10/10/2015 9:25 am
Circular crack of doom was only on earlier 'normal' Tallboys, it was changed before LTc arrived and the LTc doesn't suffer from it at all AFAIK
Posted : 10/10/2015 9:34 am
I was scouring the Internet and came across this thread from a few years ago on STW.
"Looks like the 2013/14 Bronson / Solo / Tallboy Carbon2 now have square inserts as opposed to the circular ones in the lower link mount, time will tell I suppose as to whether cracks form but the square shape should prevent this."
Just wondering if all Ltc's came with square inserts??
Posted : 10/10/2015 10:06 am
Maybe check the cracked Bronson thread for an idea of how well SC have dealt with this problem...
Posted : 10/10/2015 11:43 am
yeh, That's what spurred me to ask the question. I'm just wondering if they still used the same manufacturing process in the Ltc with regards to the lower linkage?
Posted : 10/10/2015 12:28 pm
Sorry, can somebode point me in the direction of this thread please?
My Tallboy is nearly 6 and has done 20,000 miles so would be a prime candidate for fatigue issues.
I should check this before heading to the Tour Divide oon it again next year!
Posted : 11/10/2015 2:37 pm
FWIR, it's as per bedmakers reply i.e. Only affected early Tallboy frames (pre LT ones).
I have an early TB LTc that I've owned since new; it that has seen plenty of use over very rough terrain - have worn out a few sets of linkage bearings and am on second set of linkage axles, but have not had any issues with cracking around the pivots. Fantastic bike BTW:)
HTH
Posted : 11/10/2015 6:15 pm
I've done more than 10k km on my tallboy2 carbon and there are a couple of cracks in the gellcoat, otherwise fine. It's a flipping great bike
Posted : 12/10/2015 6:04 pm
Here you go Rob
[url= http://singletrackworld.com/forum/topic/cracked-sc-trc-tallboy-carbon-frames ]Found it[/url]
Posted : 12/10/2015 6:09 pm
That's good to know that the Ltc's don't seem to be affected as I'm looking at purchasing a used one. Can't quite afford a new one unfortunately..
Posted : 12/10/2015 8:21 pm
