Does the kashima RP...
[Closed] Does the kashima RP aircan do anything or is it just bling?
Thinking of doing the tarty kashima upgrade, but I really don't like how the aircan looks. And thinking about it, I can't see where there's sliding contact in the can anyway? So, just wondering if it actually adds anything...
Posted : 09/01/2012 2:31 am
It is the internal surface of the can that is important, and the coating process does the whole can... They [i]could[/i] paint over the coating on the outside i guess, but cyclists being cyclists wouldn't want the extra weight or to lose the extra showey-offiness... I agree that they look cack though!
Posted : 09/01/2012 5:38 am
Surely the air can makes absolutely no difference as it just stores the air, the piston moves inside some shaft, not affected by the coating of the can itself.
Posted : 09/01/2012 8:26 am
The air seal runs on the inside of the can so it should make a difference.
Posted : 09/01/2012 9:36 am
edit: Neil S is right, the air seal runs on the inside of it:
Posted : 09/01/2012 10:10 am
Interesting... Did they go to SKF seals for the shocks too, or only the forks?
Posted : 09/01/2012 10:20 am
Ah, so it does- I was misremembering the innards. Cheers folks!
Posted : 09/01/2012 1:26 pm
 LoCo
Yes does make a difference less static friction, so more sensitive/easier for the shock to start moving.
Air seals are the same as before the SKF seals are just on the forks at present.
Posted : 09/01/2012 1:36 pm
