Does an XT 9-speed ...
[Closed] Does an XT 9-speed shadow plus mech exist?
 wl
As title, really. Also, anyone know where's cheapest for XT 10-speed cassettes right now? CRC coming out best so far. Ta.
Posted : 06/11/2013 4:51 pm
no
Posted : 06/11/2013 4:52 pm
Nope. Shadow plus is 10 speed only.
Try Rose Bikes for cassette.
Posted : 06/11/2013 4:55 pm
I believe you can frig a shadow plus mech to run 9-speed with 9 speed SRAM shifter and a 6mm spacer.
I haven't tried it yet though
Posted : 06/11/2013 4:57 pm
 wl
Cheers. And what's i-spec all about?
Posted : 06/11/2013 5:14 pm
I-Spec means the shifter bolts directly to a hole on the underside of the current model Shimano brake levers. IF your brakes aren't Shimano, you'll have no way to mount an I-spec shifter.
Posted : 06/11/2013 5:22 pm
 wl
honour - cheers for that. Guess that means one less clamp to clutter the bar - useful with a Reverb on there. I've got what I think are last year's XT brakes, so perhaps I'll be ok. I'll check later.
Posted : 06/11/2013 5:27 pm
9 speed Shadow, Yes....
Shadow Plus (with a clutch), Dynasys only, so its 10 speed, clever bodgery, or no clutch...
Sorry.
I-spec - basically direct mount of shifter to the brake lever clamp (for less clutter) like matchmakers...
Just to add a wrinkle there's two types of I-spec apparently, [url= http://singletrackworld.com/forum/topic/shimano-i-spec-b ]see this useful thread[/url]
what does the shadow'ness get you over a standard XT?
Posted : 06/11/2013 5:37 pm
Shadow is more compact. The idea is that the parallelogram doesn't project as far away from the hanger and so is less likely to be ripped off from errant rocks / tree stumps etc.
Posted : 06/11/2013 5:40 pm
 wl
Shadow is great - these mechs seem to outlast Sram by literally years for me. I marginally prefer Sram's X9 action to XT, but I can't afford to keep replacing them when they explode on rocks.
Posted : 06/11/2013 5:42 pm
Plain shadowyness was just a slimmed down fixing and relocation of the actuating arm to the arse end of the mech to reduce it's profile and make it less prone to rock strikes.
Shadow[B]plus[/B]-ness added a clutch to reduce chain bounce and improve retention, unfortunately this was only added after everything went 10 speed (Dynasys) and different cable pull ratio was employed, hence no 9 speed variant...
The buggers! Its almost like they want you to buy a whole new drivetrain or something...
Posted : 06/11/2013 5:46 pm
As jam bo mentioned above a Shimano 10 speed clutch mech will work with a 9 speed SRAM shifter using a 6mm spacer btw the cable and mech fixing point.
I've done it on 2 bikes and it works spot on. 😀
Posted : 07/11/2013 2:49 pm
Getting any parts above Deore level in 9-speed is becoming increasingly difficult according to my LBS. 😡
Posted : 07/11/2013 3:24 pm
not much weight difference between SLX and XT 10sp cassettes either
not £30 quids difference anyway
EDIT - OnOne had the SLX at 34.99 earlier in the year, but not sure what they are now
Posted : 07/11/2013 3:28 pm
xt cassettes are only £37
http://www.chainreactioncycles.com/shimano-xt-m771-10-speed-mtb-cassette/rp-prod52281
Posted : 07/11/2013 3:33 pm
 wl
100mphplus - thanks for this, any chance you could stick a photo up on here of the adaptation? I could then presumably keep my x9 shifter and run it with the 10-speed shadow plus. No worries if it's a pain.
rob jackson - cheers, bagged one of these yesterday, along with an £18 bottom bracket. Bargain.
Posted : 07/11/2013 5:07 pm
wl - this is the thread you need. I set a 10spd SLX mech up on my 9spd SRAM shifter 6 months ago and like others say it has been perfect.
http://singletrackworld.com/forum/topic/9-speed-sram-shifter-with-a-shimano-10-speed-clutch-rear-mech-will-it-work
Posted : 07/11/2013 5:21 pm
 wl
Dyffers - cheers for this. I'd just started a separate thread asking for info/pics, but you might have done the job. I'll see what other info comes in anyway. Thanks v much for your link tho - it'll be great if I can save myself the cost of a new shifter without too much hassle.
Posted : 07/11/2013 5:27 pm
