Does a Chunky Monke...
[Closed] Does a Chunky Monkey fit in a Scandal with much clearance- 29er styley?
At the rear?
Oh and do they fit in under the arch of Reba 29er forks okay as well?
Looking at upping my grip levels...
Thanks
Posted : 16/08/2013 10:04 pm
 nuke
What's a CM...is it 2.4"? It'll be tight...I have Smorgasbord front and rear on my Scandal 29er and its fairly low clearance on the chainstays and they are 2.25
Posted : 16/08/2013 10:20 pm
Yep, the Chunky Monkey's are 2.4s.
I have some Racing Ralph 2.25's right now. Not much clearance at the back (maybe 6 or 7mm either side of the side lugs)so was worried about going any bigger.
Was out on my local trails today and they were a bit wet for the 1st time in ages. Struggled for grip on a few climbs, had a few rear end sliding sideways moments on some of the steeper DH's and it has made me start to think about a bit more grip. Maybe a CM is a bit too much...
Posted : 16/08/2013 10:34 pm
 nuke
I'm liking the smorgasbord, extreme front, enduro rear...perhaps try them. I do have Ralph's and SBs will be a step up in grip from the Ralph's. They came in at 920g so CMs will be even weightier. I run them tubeless...thick sidewalls, they go up easy on my Crest rims
Posted : 16/08/2013 10:39 pm
920g!
Crikey and a step up in weight. But this tyre change is for the 'rainy season' so will have more things to worry about than weight.
Thanks
Posted : 16/08/2013 10:53 pm
I do like the polarised views on tyre weights! I was thinking of CM SB as light weight race tyres that would cope with my clumsy lack of style :mrgreen:
Posted : 13/09/2013 1:27 pm
I have CMs (the 50/42a ones) on 29er Crests (at the moment)
The two tyres weighed in at 900g and 940g when I got them.
On a Crest the CM on the front fits into my Reba with plenty of clearance. Enough clearance that this weekend I'm going to see if it'll still fit mounted on a P35 rim.
At the rear, again on a Crest, I had plenty of clearance on my Singular Swift, and even more on its replacement Yelli Screamy. I guess clearances on a Scandal would come up smaller than both of these though (no experience of a Scandal). A quick test in the garage (but never ridden) and it *just* fit into the back of my Niner Air9.
HTH
Posted : 13/09/2013 3:36 pm
