Each to their own, but if you cycle on the roads when its dark and you dont wear a hi viz vest or similar IMO your a bell end. If you dont wear a helmet at all, again your a bell end.
Fair enough. IMO you're a cock 🙂
Only because it seems a bit silly to say each to there own and then insult people because of their opinions!
Graham - I have found it hard to get specifics. there is a standard for reflectivity and for size I think - tape should be able to meet it.
Just been looking. The relevant law seems to be [url= http://www.legislation.gov.uk/uksi/1989/1796/regulation/18/made ]Section 18 of the The Road Vehicles Lighting Regulations 1989[/url] which basically says you must use the light and reflectors specified in the table.
For pedal cycles that table says we need a "Front position lamp, Rear position lamp, Rear retro reflector and a Pedal retro reflector".
The definition of a "Pedal Retro reflector" is in [url= http://www.legislation.gov.uk/uksi/1989/1796/schedule/20/made ]Schedule 20[/url] and says:
Number: Two reflectors on each pedalLongitudinal: On the leading edge and the trailing edge of each pedal
Lateral:No requirement
Vertical:No requirement
Angles of visibility: Such that the reflector on the leading edge of each pedal is plainly visible to the front and the reflector on the trailing edge of each pedal is plainly visible to the rear
Markings: A British Standard mark (specification for photometric and physical requirements of reflective devices published by the British Standards Institution under the reference BS 6102: Part 2: 1982, namely “BS 6102/2”)
Size of reflecting area: No requirement
Colour: Amber
So there you go. Technically tape [i]probably[/i] wouldn't meet the requirement as it won't have a British Standard Mark.
Though if you had tape as you described you would hope any sensible judge would tell them to stick such technical objections where the sun doesn't reflect.
I don't think many (if any) decent bike lights these days conform to BS 6102/3 either (hence are illegal for road use unless coupled with a crappy but legal light)
When commuting yes. A high Vis Gillet. Also a hope Vision 2 flashing light.
I just think when commuting in anycity centre you can never be too careful!
However when just out riding on the road, no I don't bother...
Police need to clamp down on the tinted glass, people only have it so that can get away with using there mobiles phones, tricky to see hi viz through that stuff, constantly pulling out on me.
Reflectives *do* only work when light shines on them but they're really bright when it does (and will have a larger area than your rear front or rear light). More importantly, ankle or pedal reflectives move in a way that says very clearly 'cyclist'. When I'm driving a car they make a big difference to how visible cyclists are.
They're also a really good back up for those times when your lights fail.
For me it's Conti Reflex tyres plus ankle bands. Rucksack, waterproof and windvest in a bright colours (not black). Sam brown belt or windvest on top if I'm riding in normal clothes in anything other than bright light.
I don't get the desire to look like some kind of Ninja (who, remember, wear black to *make* themselves invisible) when riding a road bike or commuting. Buying colours that have a chance of showing up costs nothing.
The law was changed recently to make LEDs legal.
There is a maximum brightness for bike lights though. Can't remember the numbers, but on the cheap halogen lights from Argos that I had a few years ago the flood was the maximum legal brightness and the spot was two or three times as bright.
[url= http://www.ctc.org.uk/desktopdefault.aspx?tabid=4071 ]CTC article on light regs[/url]
The regs are a bit skew-whiff, aslong as you have the reflectors and a light that emits as many lumens as a sick glow worm you are legal, go for the christmas tree approach and you can still end up illegal. Certainly my rear facing white flasher on my helmet will get a black mark.
Real world police aren't going to pull you if you're well lit and visible...
but obviously the insurance companies will still try to "keep their costs down" if their client mows you down anyway, then expect a fine tooth comb. Seeing as how the only legit pedals are the rubbish plastic ones you get on BSOs (or the rubbish spd clip ons) most of us are in trouble.
