Do you Lube/Grease ...
[Closed] Do you Lube/Grease Front and Rear Mechs'?
[#11949823]
As above really. I'm talking about a standard road bike here- I used to own a pretty cheap road bike and I don't ever recall specifically lubing or greasing anything on the actual front or rear mech and they seemed to work fine for quite a few years (and still do).
I have a much nicer/more expensive road bike now and after riding 60miles in torrential rain I'm wondering if I am being too neglectful?
A quick google re: the front mech seems to indicate I should spray with degreaser and then douse the whole thing in teflon lube... for some reason I feel a bit reluctant to just blast my front mech with degreaser though, even if I am re-coating with PTFE...not sure if I'm just being daft?
I realise I am probably massively over-thinking this.
Posted : 06/07/2021 5:11 pm
A spray with GT85 every so often is as much as I do, has kept my Ultegra 6800 running fine for the past few years.
Posted : 06/07/2021 5:29 pm
Pivot points on front and rear mechs get a spray lube and a wipe down with a rag every now and again.
The front mech can seize up over the winter due to getting sprayed with salty cack from the rear wheel.
As the others do - spray a bit of lube into the pivots and work it back and forward a few times. I just freed off a stuck front mech like this.
Its a part of my regular maintenance. I have 20+ year old mechs on some of my bikes.
Posted : 06/07/2021 5:34 pm
 Aidy
I drop/spray some lube (whatever I happen to have to hand) at them whenever I notice they're a bit sticky.
Posted : 06/07/2021 5:36 pm
Pivot points with WD 40 every now & then.
Posted : 06/07/2021 5:54 pm
In the winter to stop them freezing up with ice
Posted : 06/07/2021 5:59 pm
Spray with GT85 every so often and also after washing the bike.
Posted : 06/07/2021 6:27 pm
Cheers everyone. I think I'll do the same then and show them a bit of love with a rag and some GT85 every now and then and maybe skip a total de-grease (which does seem a little unneccesarry looking at it)
Posted : 06/07/2021 6:31 pm
GT85 after wet ride or washing to displace water and a silicone spray every now n again, cut up cereal boxes for putting behind the mech before squirting owt.
Posted : 06/07/2021 6:50 pm
As others GT85 squirt on the pivots after wet ride (or wash) - I always put a rag under the front mech to stop any GT85 getting into the BB bearings.
Posted : 06/07/2021 6:56 pm
Occasionally spray on some chain degreaser when washing the bike, followed by warm water and suds, rinse, dry off and a soft of 3in1 on the pivot points.
Posted : 06/07/2021 7:30 pm
