Do you change your ...
[Closed] Do you change your chain at .5 stretch? Xx0/1 users
Bought a park cc-2 chain checker ( the one with the pins on) it seems much easier to tell precise chain stretch rather than a .75 / 1.0 go/no go type one
The lbs suggested changing the chain on xx1/0 about .5 to prolong the cassette, just wondered who else is doing this or are you still changing at .75 and still having the same slick shifting from a new chain?
Interested to know as don't want to waste chain life but at the same time dont want to accelerate cassette wear for the sake of changing a chain a bit more frequent?
Posted : 30/01/2014 8:43 pm
.5 on a park checker is almost new!
I wait a lot longer than that Sram Xx and xx1 cassettes seem to have a good wear rate and last a fair while.
Posted : 30/01/2014 8:51 pm
I haven't even got a chain checker. If it lasts as long as the XX one I had before, it will be fine. The only ring that really wore was the big aluminium one, and I barely use that on the big cassette now.
Posted : 30/01/2014 8:59 pm
I have a new xx1 chain and that read .25 just under just as a test, my current xx1 chain is just under .5 now through the windowed gap, so I reckon it's ok just yet then cheers blazzin will keep an eye on it then
Posted : 30/01/2014 9:00 pm
 rone
I think it's between the two from what I've read.
I've just switched mine at 1200 miles, about .70 or so. Experienced much more wear on triples. I use rock n' roll lube and keep the thing clean.
Posted : 30/01/2014 9:03 pm
Cheers hob nob have heard a few people say now how great the life span of these / xx cassettes seem to have , I was worried if already gone over it , but upon checking relieved to say it's only just .5 at the moment
Rone I agree I'm properly cleaning my chain after every ride so maybe that's why it's wearing quite well, as soon as the park tool looks like it's over the .5 % mark (not totally visible in the window ) I'll change it, everytime I clean the chain it basically rides like a brand new transmission, so smooth the xx1 stuff at shifting, hoping it stays this way and I don't forget about changing before it's too late
Posted : 30/01/2014 10:28 pm
wet or dry lube? whats the difference? ive always used finish line teflon, not sure which of the above it is.
Posted : 31/01/2014 1:35 am
finish line Teflon with the red cap is dry.
Posted : 31/01/2014 8:30 pm
