Do I have a leg to ...
[Closed] Do I have a leg to stand on...
[#6843345]
So, crossed over yesterday and bought a spesh roubaix. So, after only 40km the chain pin where they join the chain worked its way loose, got snarled in the front mech and pulled chain up into the frame causing a small scuff to the chainstay.
I don't think this is my fault and clearly a fail on either their behalf in not fitting the pin correctly or shimano's. Should I push to not only get the chain repaired at their expense, but also the frame touched up?
Never had one of these issues before so not sure.
Posted : 08/02/2015 12:10 am
good luck....
Shimano will have a no consequential loss clause
Is the chain dead or just need rejoined?
Posted : 08/02/2015 12:13 am
Their fault but no idea how you will prove this
Posted : 08/02/2015 12:17 am
Saves you a job.
Go to the shop.
Be nice.
Get it fixed.
And get a freebie or two.
Win.
Posted : 08/02/2015 12:29 am
The pin is still there, but I just think they should sort it. I could do it myself. Sadly, I didn't have a chain tool with me when I was an hours ride from home.
Posted : 08/02/2015 3:48 am
If you are going to take it in, might as well get them to check the mech hanger is still straight.
Think yourself lucky it didn't bend the hanger, snap the mech and take out half the spokes!
Posted : 08/02/2015 7:06 am
serves you right for buying a road bike.. Just sayin 🙂
Posted : 08/02/2015 10:54 pm
Do this
Rorschach - Member
Saves you a job.
Go to the shop.
Be nice.
Get it fixed.
Win.
Be grateful this didn't happen
spooky_b329 - Member
Posted : 08/02/2015 11:26 pm
Remember that "they" were the factory in Taiwan rather than the shop the did the final bits n pieces
Posted : 08/02/2015 11:39 pm
40 clicks & it's broken. Well, my approach would be to fix it myself & double check everything else in the process. However, this is a sale of goods issue & returning it to the shop that you purchased it from would be appropriate. If two months on you find "something" wrong related to the chain snapping & haven't told them then you won't have a leg to stand on.
Posted : 09/02/2015 8:34 am
 hora
How could the shop have foreseen that?! How is it their fault. See what they say though as I doubt the bike was cheep!
Posted : 09/02/2015 8:37 am
If it isn't structural, I'd do a small sad, and then not worry too much. Worse will happen at some point that will be no-one's fault at all. I'd had my last shiney, new roadbike for about 2 weeks before I laid it down in a corner and gave it a good scuffing.
Posted : 09/02/2015 9:03 am
Take it back and ask very nicely if they would check the bike over. Explain what happened and just ask if they wouldn't mind touching the paint up. I wouldn't go in guns a blazin'.. 🙂
Posted : 09/02/2015 9:16 am
As above, take it back, explain what happened and ask them to rectify.
The shop staff will ask you if you had the chain on big-big. That shouldn't break it but you didn't did you?
Posted : 09/02/2015 9:18 am
 kcal
- ah, the old roadie travels light gag, which is fine until something goes wrong..
Posted : 09/02/2015 9:29 am
As a previous poster mentioned, the shop does not fit the chain during the pre-sale build (PDI). It's fitted on an assembly line in Taiwan.
The PDI on a Specialized bike involves cabling the brake/gears, fitting front wheel, seatpost, pedals, bars into stem, and setting up the bike.
You would be within your rights to ask the shop to change the chain for a new one (as the original failed) perhaps KMC, and the shop can easily get Specialized UK to credit them for this cost.
The mark to your frame is one of those things. Again you'd be within your rights to ask to have the bike replaced, but its going to get scratched sooner or later..I would not bother.
Posted : 09/02/2015 9:50 am
Many years ago when I worked in a lb, checking the chain for stiff links, if fitted making sure the split link clip was fitted the right way round was part of the pdi.
Posted : 09/02/2015 9:55 am
I'd go back,explain what happened. See if they will touch-up the paint scratch and replace the chain with possibly better spec one. If it was a Shimano chain it should not have had a split link in it if fitted on the line at the factory. Keeping calm and not going off on one makes a heck of a difference. Take the shop boys a bag of Haribo when you pick it up too!. 🙂
Posted : 09/02/2015 11:00 am
