DMR sidekick, what ...
DMR sidekick, what bb?
 DT78
[#12726576]
I have an old dmr sidekick frame I’m looking to rebuild for my son, it is chocolate brown, sidekick 3 I think from at least 10 years ago.
It has a bb I don’t recognise. A bit like a isis one it originally had dmr cranks. A quick revivew on the park tools website has left me more confused!
Couple of questions for the font of all knowledge, what bb is it? What tool do I need to remove and can I fit shimano bb and slx cranks?
If no one knows from the description I’ll dig it out of the loft and take photos tomorrow
Posted : 16/02/2023 7:53 pm
 DT78
Maybe it is an isis bb from crisis cranks?
Posted : 16/02/2023 7:55 pm
Euro BMX BB possibly?
Posted : 16/02/2023 8:18 pm
original DMR cranks had a splined BB axle much like a BMX but cups to fit a 68mm threaded BB, looked like an ISIS BB, was not a sealed cartridge but had a fixed cup and non-drive side had a lock ring like a cheapo cup and cone BB but with cartridge bearings. Came out around 2000, weighed a ton, I had some on an original Santa Cruz Bullet. I have an original DMR Sidekick, it has a 68mm threaded BB shell so should fit most modern cranks. Later ones may have had a BMX BB shell as I think some of their frames did, do some measuring of the BB shell on the frame and a bit of google
Posted : 16/02/2023 8:21 pm
 DT78
BB
Posted : 16/02/2023 8:51 pm
 DT78
Its says 68 / 73 shell so I think you are right Dom, any idea what tool is needed to remove it?
Posted : 16/02/2023 8:52 pm
I can't be sure from that picture but it's either a US BMX bottom bracket (which it does look too small to be) or a normal BSA threaded shell.
With that in mind it should be easy enough to measure and figure which it is. If it's BSA then either the proper tool or a hammer and sacrificial flat head screwdriver will shift it.
@d42dom are you talking about the old Chieftain cranks? I don't think that's what this is for, they were proper 3 piece.
Posted : 16/02/2023 9:11 pm
Shona I octalink Bb tool park ref bbt18
Luckily the standards been repurposed as a lock ring for e-bike motor sprockets so tools still widely availible .
Can get no name ones on Amazon for a couple of quid which beats finding out your bb is stuck and beating on it with a hammer mangled it
Posted : 16/02/2023 10:16 pm
But not nearly as fun. Still have great memories or hacksawing the BB shell out my General Lee. 😉
Posted : 16/02/2023 10:37 pm
Before or after you parked it in a tra sit vAn 🙁
Posted : 16/02/2023 10:52 pm
Umm, well after. Yeah it must have been because I'd moved into my own place when I did the BB surgery. Was still going strong when I sold it to a mate.
Miss that one. Never missed the van though.
Posted : 17/02/2023 1:52 am
@d42dom are you talking about the old Chieftain cranks? I don’t think that’s what this is for, they were proper 3 piece.
That's the ones, they deffo did them for 68mm shells though as above. It was when the first came out, proper pain in the arse!!
<div class="bbp-reply-content">
</div>
You can remove the lockring with hammer and punch/screwdriver. I'm pretty sure the DMR Chieftain cranks I had were normal BB tool of the time. I would probably go at getting the cups out with pump pliers or similar, more suitable tools maybe available! Having been a bike mechanic late 90s early 2000s most new things were a pain in the arse!
Posted : 17/02/2023 12:22 pm
