Diy tubelessing of ...
[Closed] Diy tubelessing of rims
I want to tubeless some flat 50mm B+ rims, tyres are very loose on them so I need to pack the width of the time out.
Any ideas of what to use?
I wondered about closed cell foam packing material, no idea where to buy. Bubble wrap surerly too fragile (tho I am tempted!)
Posted : 20/04/2016 10:32 pm
Pipe insulation?
Posted : 20/04/2016 10:34 pm
Camping mat if you have a deep well to fill. Dirt cheap from Argos.
I then use electrical (insulation) tape to seal and create a smooth surface.
Posted : 20/04/2016 11:12 pm
Ghetto them...
I've had folk question why I ghetto' my Dually's...
TBH, it was just easier.
Tyre went on, sealant in. No frantic pumping, they went up with hardly any air loss at all.
Posted : 20/04/2016 11:21 pm
Way too loose for that taki.
Cheers guys!
Posted : 21/04/2016 8:28 am
I'd try the bubble wrap. It only needs to fill a gap, not resist any particular forces. It's done its job as soon as the tyre's seated, so it doesn't need to be durable. Parcel tape over the top, see what happens.
Posted : 21/04/2016 10:17 am
I probably will, buy it will need to resist 15psi odd of tyre pressure.
Posted : 21/04/2016 12:48 pm
