DIY light people - ...
[Closed] DIY light people - heat shrink tubing?
Do any of you use heat shrink tubing? I need to repair the stuff on my Lupines, and it's definitely heat shrink tubing but the stuff available from Maplin is rubbish.
Posted : 21/01/2009 5:58 pm
I've got loads of it mate
What size do you need?
Send me an email with your name and address to matboulton@yahoo.co.uk and i'll pop you some in an envelope
Mat
Posted : 21/01/2009 6:10 pm
Rubbish how?
I use it, but not for anything on my DIY lights at the moment.
Posted : 21/01/2009 6:11 pm
chewi, (cheeky kit content comming up) fancy sending me an inch or two too, could use it to tidy up the connection om my home made lights
Posted : 21/01/2009 6:32 pm
I've used the stuff from Maplin okay. Even when I didn't have access to a heat gun, I managed to make it shrink okay over a gas cooker flame.
Joe
Jamie,
No problem but please don't everyone shout otherwise it'll cost me a fortune in postage!
Don't forget to let me know what size.
Mat
Posted : 21/01/2009 6:41 pm
If anyone needs heatshrink, try your local fishing tackle shop, as its used a lot in carp fishing rigs, you get quite a good price and it shrinks down perfect every time, recomend ESP branded
Posted : 21/01/2009 7:42 pm
I heatshrink every join if at all possible -all helps reliability
Posted : 21/01/2009 9:03 pm
 benz
Try the steam from a kettle for shrinking it.
And no - never had any shorting issues either.
Posted : 21/01/2009 9:51 pm
Resurrecting old thread here, cos I forgot to check back..
The Maplin stuff I found wasn't flexible enough. I had double layers where I went from a thick bit around the plug to the thinner bit on the main cable, and this caused a tight bend at that point - and other places where I'd doubled up. Consequently I've got to strip it all and do it again.
Posted : 03/02/2009 3:29 pm
Fishing shop only had 2" long bits. Seriously.
Posted : 03/02/2009 5:54 pm
I think I remember Toolstation do it, so Screwfix might as well? Any electrical factors will sell it too.
Posted : 04/02/2009 1:05 am
Seem to remember from previous threads that you're in the Cardiff area, give me a shout at Sunset (not Wed.,i'm off then),I've got all sorts of sizes at home.
Posted : 04/02/2009 8:14 am
Coatesy, will do - that your real name? Will I get looked at weirdly for asking for someone by that name? I often get looked at weirdly in there 🙂
Bring some in, I'll drop you some cash or just buy something - I need fork oil for starters.
Posted : 04/02/2009 12:08 pm
We're all wierd in there too,ask for Craig if you want, but Coatesy will do. What size are you looking for as i've got a few different sizes?
Posted : 04/02/2009 2:37 pm
Er well I've got two thick wires and a thin one to cover. So I dunno, I want it to shrink down to say 3-4mm diameter? Then some thicker stuff, 6mm or so for the joins. See you tomorrow probably. My name's Ben, I'm remembered in there for having bought to Patriots, a 5 and a Kona Dew in the space of about 4 months. First one was a £1500 bargain with 66 coils on it (mmm) and the rest were insurance replacements. The tall guy knows me, I dunno if you're him or not tho 🙂
Posted : 05/02/2009 3:34 pm
