DIY light bodge. Bi...
[Closed] DIY light bodge. Bit of fun. Will I die? ...etc
Tinkering in the shed at the weekend, and found an old GU10 LED bulb that the lens had fallen off. The bulb was one from a test batch I had put together for the lighting in the house.
[url= http://www.onlinebulbstore.co.uk/products/LED+Light+Bulbs/High+Performance+LEDs/High+Performance+GU10+LEDs/Decor+7W+GU10+Quadruple+High+Power+LED+-+Warm+White+%287+Watt+GU10+LED%29/1884554210 ]Bit like this one[/url] although Its a triple at 7W not a quad (although the photo looks like a triple there)
Pulling it apart I found the electronics which I assumed had to step the voltage down from 240 to something 10-15v ish. Yanked it off and connected the fly leads directly to a smudgepack at 14.8v and waddayaknow it worked! 🙂
Absolutley no idea how much juice the three LEDs draw, or how long the 2.6Ah pack will last or whether Ill burn the LEDs out.
The lens had a honeycomb finish to it so I sanded it clear with some 400grit wet and dry and then polished with some brasso. Stuck it all back together, jammed it in a spare torch bar mount and fitted a [url= http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260821528252 ]DC POWER JACK -FEMALE CONNECTOR CCTV DVR 5.5mm X 2.1mm[/url] 4 for £2.25 from eBay which connects to the smudgepack/troutpack. Very handy if you fancy bodging your own.
[img] https://lh6.googleusercontent.com/-anX8NGmIlWw/TkuAsuYoz9I/AAAAAAAAAiw/lDnnv4sWkf0/s400/P1010089.JPG [/img][img] https://lh6.googleusercontent.com/--tOCyvRk9yk/TkuAuf-J32I/AAAAAAAAAi0/QO93zXudJWM/s400/P1010090.JP G" target="_blank">https://lh6.googleusercontent.com/-anX8NGmIlWw/TkuAsuYoz9I/AAAAAAAAAiw/lDnnv4sWkf0/s400/P1010089.JPG [/img][img] https://lh6.googleusercontent.com/--tOCyvRk9yk/TkuAuf-J32I/AAAAAAAAAi0/QO93zXudJWM/s400/P1010090.JP G"/> [/img]
Will try and get a beam shot tonight. It casts a lot of light out, but at 36degrees and no hotspot in the middle. Should be fine left on the pub bike until it blows up anyway 🙂
Posted : 17/08/2011 10:01 am
Not bad.
Interested in the shots so ill keep an eye out.
Posted : 17/08/2011 10:05 am
Probably, can I have your bike / wine collection? 😀
Posted : 17/08/2011 10:15 am
stoner if yo8u really like taking risks I can upgrade some critical parts of your bike with carbon fibre?
Posted : 17/08/2011 10:19 am
You do the brakes and I'll get WCA on the electrics.
Posted : 17/08/2011 11:23 am
Well it works, didnt get a beam shot Im afraid. Didnt blow up. Big pool of light. Plenty bright out to 15-20m. Probably equivalent to oldskool 35W halogen I reckon. Will try again tonight.
Troutie, what kind of current/voltage do you think is going on in there?
Posted : 18/08/2011 8:42 am
