disk brakes - spaci...
[Closed] disk brakes - spacing required for different units on same rotor and adapters
hi - just curious before i start spacing and bodging...
i was running Cannondale brakes - post mount 180 front, 160 rear with adapters
went to change for some Sram Guide REs that were on my other bike - also PM and same rotors - when i attached to the adapters they are fowling the rotor
is this pretty common - have i again assumed there would be some standard here in the bike industry that doesn't exist and i will have to space these out
This tech doc suggests a configuration - but at a glance this won't fix my problem as the space is required between the adapter and the brake unit
cheers for any pearls of wisdom
Posted : 26/07/2021 9:50 am
The adapters are fouling the rotors?
Pics would help
Posted : 26/07/2021 11:29 am
Put washers under the caliper to move it out a bit. I have the correct mounts on my bike but needed about 1mm to stop the outer edge of the rotor touching the caliper.
Posted : 26/07/2021 11:43 am
cheers @pipm1 - i feel confident giving that a go now i know it's a shared issue
(fair point @tillydog - i'll get pics if still not working)
Posted : 26/07/2021 11:52 am
