Disc cyclocross rim...
[Closed] Disc cyclocross rims that will take higher pressure road tyres with tubes?
Hello all.
I've got some Pacenti CL25's in mind for a wheel build for my 'cross / gravel / commuter bike.
I'm wondering if there are any others that will safely take tyres with tubes at pressures up to 80psi?
I like to run 28s or 32s, anywhere from 40-80psi. I am not into deep section rims - hence the CL25's work for me, but they can't be the only ones?
Stan's seem pretty cagey about using anything over 60psi even with a tube.
Thank you - all help much appreciated.
Posted : 10/12/2017 6:03 pm
I thought that was only for tubeless?
Posted : 10/12/2017 6:16 pm
DT RR421's or R470's fit the bill.im running 421's on 32's ATM and they're pretty bang on.
They also do the R500 which is even wider but really designed for 35+
Posted : 10/12/2017 6:45 pm
I ran stans grails at with a tube in 80-90 psi no worries
Posted : 10/12/2017 6:47 pm
Hi all, and thanks!
Yeah I’d like to use Stans but the advice isn’t clear, and I’ve heard a few folks reporting blowouts with tubes.
I’ll check out the DT wheels. A 9mm thru axle option on the front would be a bonus too as I’m using a Cotic steel fork
Posted : 10/12/2017 7:23 pm
h plus son hydra
Posted : 10/12/2017 7:48 pm
I have some h plus sons Hydras - no idea on maximum pressures but they are hardcore enough to put up with my cack handed jumping off kerbs etc.
Posted : 10/12/2017 7:50 pm
Nowt wrong with the CL's. I use them at everything from 40 to 100 psi. Asked the importer who suggested that it wasn't any thing to worry about but to tlak to the tyre supplier.
Posted : 10/12/2017 7:51 pm
Pacenti SL25?
Posted : 10/12/2017 7:57 pm
 tiim
Stan grail, good for 115psi according to them [url= http://https://www.notubes.com/grail-rims ]linky[/url]
Posted : 10/12/2017 9:22 pm
+1 for Grails. 100psi all year with no problems (Schwalbe One Pro 28 mm)
Posted : 10/12/2017 10:07 pm
Tim... linky no worky. Interested though.
Will check out the Hydras Jim.
Yeah I like CLs.
Posted : 10/12/2017 10:09 pm
Grails again here with tubeless 28mm Schwalbe Pro ones. Also have Pacenti SL25s running G-One Speed 40s at 50+psi, again tubeless.
Posted : 10/12/2017 10:15 pm
I am using Mavic XC421 and running 23c tyres at around 100 PSI with tubes. Have been fine with tubes but guess they wouldn't be tubeless at 100PSI
Posted : 11/12/2017 9:30 am
The new 2017 Grail Rims claim that you can run 25-32mm tyres with or without tubes up to 115psi.
Posted : 11/12/2017 9:38 am
I'm running 28mm tyres at 90psi on Stan's Grails.
According to [url= https://www.notubes.com/grail-rims ]Stan's website[/url], Grails are good for:
Max Pressure with 23mm Tire: 116psi
Max Pressure with 28mm Tire: 100psi
Max Pressure with 32mm Tire: 45psi
Also printed on the rim:
Posted : 11/12/2017 10:08 am
That's the older version. The new rims use BST-R rather than just BST.
Posted : 11/12/2017 12:14 pm
Ok, so there seem to be 3 sources of information:
[list]
[*][url= https://www.notubes.com/grail-rims#product-info-specs ]"Archive" Grail page[/url], which is what I linked to above.
[/*][*][url= https://www.notubes.com/grail-rims-1#product-info-specs ]"New" Grail page[/url], which has different figures under "specs".
[/*][*][url= https://www.notubes.com/technology/bst-r ]BST-R tech page[/url], linked from both, which states "115 psi max for 25-32mm".
[/*][/list]
Posted : 11/12/2017 12:40 pm
The Hope 20Five rims go to high pressure.
Posted : 11/12/2017 12:45 pm
I believe Stans Alpha 340 or 400.
Road specific tubeless rim.
Running tubeless at 90psi can’t see why you can’t run tubes in them at that pressure?
I thought a lot of the limits on the rims were to do with tubeless tyres blowing off rims ?
Not so much a problem with tubes at higher pressure?
Thanks,
Max
Posted : 11/12/2017 2:20 pm
