so a set of brakes is required for a trail bike build, they need to be cheap, reliable and able to have some feeling not on or off
options on the web I have seen are
Magura MT 2 or 4 at CRC around 25 to 40 per end total 80 no rotors or adaptors but plenty in the shed
Formula Megas merlin 109 for the set inc rotors and adaptors
Shimano slx around 90 pounds
Thoughts? Recommendations? experinces?
I like my MT2's but go for Deores.
any reason?
On various bikes I have Deores, SLX, MT2's , Elixirs and Zee's. So I have quite a mix.
MT2's are great, but I worry about the plastic clamps on the levers. They also need a lot more work to cut hoses, even if you buy a hose close to what you want. They have a great feel with sintered pads and decent discs. I destroyed the Magura discs on a trip to Spain. I have them on a commuter with some old Hope discs and don't miss a beat for the last year.
Deores just seem to work brilliantly. Easy to cut hoses. Decent non flexing levers. Easy to bleed and get Shimano fluid.
SLX are as above but with an adjuster, which I never move and ceramic pistons. Seen Deores in Spain with normal pistons and they never overheated, so not really needed.
Had both MT2 and 4. They are great and really light, but I eventually replaced them with XTs as I kept bending the levers in crashes and parts were stupidly expensive. However, if you are getting them for the price you say then that is no issue.
I've got a spare 203mm Storm rotor if you are interested.
they feel identical to slx but are cheaper. deores use allenkey adjustment and slx have a dial. The deores use a split pin and the slx use a screw in bolt i believe are th eonly differences. maybe someone else with more knowledge would be able ot tell you more.
XT has a screw pin, slx and Deore are both split pin for pads.
Magura's are utter shite, so shite I feel the need to seek out every thread that mentions them and bad mouth 'em.
Got magura MTS,s far too much plastic, the bar clamp uses silly nuts that as you tighten them you get less and less engagement of the tool, to the point it's right but you can't undo them. The deores had great feel, and on another plus side if you run spyres it's the same pad, meaning less money in spares.
Slx is threaded for the screw pins which cost £3 each at wiggle. Don't know if deore also threaded.
real shame as the old magra louise and martas were great brakes
I've just fitted some deores on a mates bike, in the few times I used them I couldn't feel much difference between them and the XTs on my bike so I'd go for the deore.
I just bought SLX from Wiggle £86.something for F&R.
I have some Sram Guide R just taken straight off a new bike if you are interested.
I am if he´s not!
Email in profile.
Price?
Slx are nice over deore-
Better finish
Can put a pad screw in rather than spilt pin
Ceramic pistons
Often come with finned pads
Hose has a banjo at caliper so can adjust hose angle
Wiggle have some Formula brakes for around £30 an end also I think, worth adding to the shortlist.
+ Ceramic pistons will stay corrosion free.
Id go shimano over mt2 ive got the mt2 and while the work faultlessly they lack out right power and some times remind me of rim brakes in the wet.
Deores are marvellous - probably heavier than the XTs, not as well finished as the SLX, but they do the job fantastically.
I've just got a pair of teh mt2s and while they work i wish i'd got deores now as i had to get the hose shortening kit, fluid and bleed stuff so if i'd just bouyght the depres i'd have spent the same and had the same brakes.
still i was suckered in but they do work nicely, easily the same power as deores here.
maguras off the list
shimano or formula
Reggie will pass on the brakes and rotor.........sram/avids nightmares of days passed
Pretty sure there is very little weight difference between derore/slx/xt
