Disc adaptor help?
[Closed] Disc adaptor help?
[#456141]
Right, obviously this isn't quite right, I figure I've got the wrong adaptor. They are Magura Odur forks, any idea what adaptor I need? If you're feeling very nice, a link to chainreaction product would be great? 😀
Also, as this is the first time I've fitted discs to this frame, what could I use as fixings? Clear zipties, or is there a more specific, and better looking system? The frame is only designed for cables, so I need adaptors?
Thanks for any help!!
Eddie
Posted : 07/04/2009 9:51 pm
is that not a rear adaptor?
Posted : 07/04/2009 9:57 pm
I think that is a 160 rear adapter, so would need a 180 disc if used on the front. This should work [url= http://www.wiggle.co.uk/p/cycle/7/Shimano_Disc_Brake_Calliper_Adapter/5360027299/ ]from wiggle[/url] or you could get a 180 disk if you want a little more power
...oops, sorry rubbish link. The wiggle one points to a whole list of bits. Its the top one but they are out of stock. Cheaper here anyway:
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=13743 ]clicky[/url]
Posted : 07/04/2009 10:07 pm
Aaaaah, that would explain it, I bought the brakes of here, secondhand, so I've got two rear adaptors! Silly me, thanks a lot chaps!
Posted : 08/04/2009 9:02 am
