Different ss ratios...
[Closed] Different ss ratios and track end length
I have a pompino and run it SS and fixed occasionally, on the road. In order to try and get a bit more off-roady I want to drop the gear ratio down a little.
If I fix 2 sprockets onto the hub, I'm happy to manually drop the chain off and swap it over when I want to change - wont happen very often, and should only take a couple of mins anyway.
Does anyone know what size change in sprocket teeth number the track end can accommodate whilst keeping the chain the same length?
I was thinking along the lines of 42t front and a 16 / 19t rear which would give me about 70 and 60 gear inches respectively.
What does this equate to in terms of the (effective) chainstay length? Is there a (easy!) way of calculating it?
Posted : 30/01/2012 3:51 pm
my pompino easily does 42:16/18 on a flip flop hub.
you might need to play with a half link so that 16 is all the way back and 19 is all the way forward.
the bigger your tyres the less adjustment you will have.
HTH.
Posted : 30/01/2012 3:58 pm
good point about the tyres. the 19t would be used with cross tyres, so that may limit it.
i have some 38's in there and the wheel needs to be most of the way back. hmmmm.....might have to have a bit of a play with it and see what fits
Posted : 30/01/2012 4:02 pm
Why not dinglespeed it?
2 rings on the front. Just keep the sum of the front and rear cogs the same eg 48/16 = 64 and 42/22 = 64 or any other combination that suited you.
Posted : 30/01/2012 4:12 pm
cos i wanna keep it simple and cheap (ie what i have in the shed) and i think that 3t difference will be enough. The only problem could be the tyre clearance.
Posted : 30/01/2012 4:27 pm
is it that simple ? thought pi was involved in it ?
Posted : 30/01/2012 4:31 pm
To go from 42-16 to 42-19 you have to slide your wheel in 8.87mm (roughly)
i have an old spreadsheet.. can email it if you like
jono
Posted : 30/01/2012 5:24 pm
trail_rat - Member
...is it that simple ? thought pi was involved in it ?
It's close enough.
Pi is for when you come in from a good ride + beer. ๐Ÿ™‚
Posted : 30/01/2012 5:31 pm
or just put two sram links in your chain so you can remove the link or two extra?
I have two chainrings on my alfined bike and do this occasionaly - when I want to drop the gear for use in snow
Posted : 30/01/2012 5:33 pm
thanks jono, that sounds like plenty of room, I'll have a bit of a play with it.
TJ, that was my other thought and probably the next "least hassle / cost" solution if i dont get even room with the same chain length.
Posted : 30/01/2012 8:12 pm
