Did I miss it all k...
[Closed] Did I miss it all kick off - or was TJ right....?
 aP
[url] http://road.cc/34527 [/url]
At a time when minister for cycling Norman Baker is in the headlines due to his choice not to wear a helmet while cycling, an academic from Norway has poured more fuel on the long-running helmet debate by claiming that they do not reduce the incidence of head injuries by the extent suggested by previous studies.
Dr Rune Elvik, an expert in risk analysis and cost benefit analysis from the Institute of Transport Economics says that wearing a helmet reduces the risk of head injury by 43%, much lower than the reduction of at least 60% he says that earlier research has claimed.
His conclusion, based on an analysis of previous research, have been published in the journal Accident Analysis and Prevention, in an article snappily entitled Publication bias and time-trend bias in meta-analysis of bicycle helmet efficacy: A re-analysis of Attewell, Glase and McFadden, 2001 which, in layman’s terms, points out what he believes to be flaws in that study and provides a reanalysis of its findings.
Deficiencies in Attewell, according to Dr Elvik, include publication bias – in other words, more weight was attached to positive findings from the researchers’ point of view than negative ones – and time-trend bias.
Dr Elvik employed a variety of techniques in his re-evaluation of the findings, conclusing that “the re-analysis shows smaller safety benefits associated with the use of bicycle helmets than the original study,” according to the article overview, which adds that “the findings of this meta-analysis are not consistent with a recently published Cochrane review,” published by the not-for-profit Cochrane Collaboration.
In New Zealand, where bicycle helmets are compulsory, the findings were reported by the NZ Herald, which adds that Dr Elvik also argues that an analysis of several studies published recently shows there was [b]“no net effect” through sporting a helmet once injuries to the head, face and neck were grouped together, because helmets increase the risk of the latter.[/b]
Professor Alistair Woodward, head of the School of Population Health at the University of Auckland and a cyclist who himself wears a helmet, told the NZ Herald: "Cochrane is usually regarded as the gold standard in pooling studies and deriving a conclusion.
"It's reasonably clear to my mind that helmets do protect people's heads and on balance they do more good than harm," he continued.
However, he agreed that helmets were not intended to guard against neck injuries.
"Whether they cause the neck to bend more than otherwise, I suppose it's possible. If there is an effect [on neck injuries], it's much smaller than the protective effect from head injuries."
Professor Woodward said he was in accord with the conclusion that modern, lightweight helmets with a soft shell protected the head less than older ones with a hard shell.
"The first helmets were [made for] rock-climbing,” he explained. “Only later, people realised the energy-absorbing material inside the shell is probably what's more important ... and the surface of the helmet has become more vented and less rigid," Professor Woodward added
Posted : 15/04/2011 5:35 pm
I once suffered concussion after crashing my bike. The force of the impact split my bike helmet. Had I not bin wearing it, there's a very good chance I wooduv sustained far more serious injuries.
Therefore, I'm not really interested in what such 'experts' claim. My helmet worked for me, so that's all the evidence I need.
Posted : 15/04/2011 5:39 pm
+1 Helmet saved me from losing most of the skin on one side of my face, it's personal choice.
Posted : 15/04/2011 5:42 pm
43% reduced risk of injury is still good enough for me. You only need to need it once to make it worthwhile.
Posted : 15/04/2011 5:45 pm
You need to read the critique of the cochrane review as well - Makes for interesting reading. http://www.cyclehelmets.org/1069.html
Links to follow from here for those who are not already sick of the subject and would like to know more
http://www.ctc.org.uk/DesktopDefault.aspx?TabID=4688
No thanks. I've known, and known of people who've undoutedly bin saved from further more serious injuries because they've bin wearing a helmet. I have never personally heard of anyone injured [i]because[/i] they were wearing one.
Posted : 15/04/2011 5:53 pm
pardon the pun, but its a no brainer really. if people don't want to, then that's their choice. helmets are so good now, there's no reason not to...
Posted : 15/04/2011 5:55 pm
Fatmax - look ate the CTC links. Helmets provide much less protection than most folk believe and across populations do not reduce the number of deaths and injury.
Posted : 15/04/2011 5:58 pm
i definitely prefer to wear a helmet and believe that they do, without doubt, give more protection than not wearing one provided they fit correctly and are worn correctly
try dropping a brick on your head;
1. With a helmet on
2. without a helmet on
Posted : 15/04/2011 6:01 pm
 7hz
Well, I'm glad that people are still researching and questioning, this is how we improve things.
This stood out to me though:
Now I have been wondering this, as I have been doing a bit of kayaking and noticed the helmets have a tough shell. Why are bicycle helmets so flimsy? It's not as if they are cheep, and if they really are worse for the softer shell, why do they make them like that?
Posted : 15/04/2011 6:11 pm
7hz - I think that thinking is out of line with most researchers who suggest that actually the shell does very little - its the EPS that does the protection.
Posted : 15/04/2011 6:19 pm
Just a thought but would a softer shell maybe help reduce the rotational forces more than a hard shell? As a soft shell is more likely to give a little.
In that vein would piss pots be better or worse then an xc lid due to shape and a harder shell? Although they do cover a large area of the head/face.
Posted : 15/04/2011 6:23 pm
slippy / smooth shell to reduce rotation. Piss pots have a smoother shell and more converage but no stats that I have seen. I have a pisspot helmet for appropriate occasions
Posted : 15/04/2011 6:26 pm
Interesting, would be good to read some research into piss pot vs xc lid in terms of protection.
Posted : 15/04/2011 6:28 pm
Headbutted a tree today!! 🙂 thank god I was wearing a helmet!! I don't see how not wearing a helmet would have been advantageous. Perhaps you could explain that to me TJ.
Posted : 15/04/2011 6:30 pm
Never seen any in those specific terms. You can find some comparisons of different types of helmet ski / cycle / motorcycle / icehockey / horse riding etc.
Snell foundation usually has good stuff on how helmets work but they have revamped their site and I can't find it now.
TRL has some as well IIRC
I've had bad crashes without a helmet on and bad crashes with a helemt on (one splitting a helmet in two).
I 'prefered' the aftermath when I had been wearing a helmet.
That said if you choose not to wear one that's your choice.
Posted : 15/04/2011 6:31 pm
I've just bought a shiny new Xar, I don't care if it saves my life because it says 'I care' and makes me ride like teh awesome.
Posted : 15/04/2011 6:33 pm
To be fair last week I had a fair sized crash and landed (then bounced) on my head toward the rear. I reckon that there was certainly some rotation and my neck was rather sore afterward, however had i not been wearing the helmet then I'm not sure that I would have bounced so well and I doubt I would have got back up very quickly. I sure as sure aren't gonna give up wearing my full face doing dh either!
Posted : 15/04/2011 6:35 pm
 Kuco
My noggin has been saved on several occasions from wearing a helmet so I think i'll carry on wearing one.
Posted : 15/04/2011 6:38 pm
Bike helmets are supposed to be sacrificial, because bad crashes with head injuries are rare. Skateboarders or dirt jumpers I suppose wear tougher more re-usable lids.
That quoted article by the way seems to talk about INCIDENCE of head injuries. Would it not be better to talk about the SEVERITY of head injuries?
If a lid means you spend a night in hospital as a precaution rather than 2 weeks in intensive care and years in therapy, that would still count as an injury in his study, wouldn't it?
I work designing support packages and rehab pathways for people who have had brain injuries, some of which derive from trauma (that is, a blow or blows to the head.) I have dealt with a number of people whose traumatic injuries result from accidents involving bikes.
The first thing to say is that if the speed of impact is much more than 35-40mph, then a helmet will be of very little help. This is not just the case for cycle helmets - the same is true for motorbike helmets.
However, if the person falls or is knocked off the bike and hits their head with a combined velocity of less than 35mph, then the helmet will undoubtedly help to the extent that it is more likely to prevent mortal injuries (ie death.) That doesn't mean there will not be injuries - indeed there will be. One of the paradoxes of greater protection is that less death is likely to mean more injuries, because more people survive who would not otherwise have survived at all. Equally, a severe injury for someone without a helmet will most likely result in a lesser injury in the same circumstances if the rider has a lid on - and in many cases a bump that might have caused a minor (but still significant)injury to someone not wearing a helmet will leave the helmet wearer a little dazed, perhaps with abrasions where the rim hits the forehead, but essentially uninjured. This happened to me a couple of years ago.
So a helmet is not a magic cloak, but it is likely to diminish the severity of what happens in an accident.........and going back to Dr Elvik, the Norwegian academic, whether it diminishes it by 60%, 43%, or even just 4.3%, then any chance of preventing people die or having such serious injuries as they otherwise might have had is good enough for me. Surely that can't be wrong, TJ?
Posted : 15/04/2011 6:56 pm
TJ isn't suggesting, nor has he ever suggested, that people shouldn't wear a helmet.
(maybe he'll do it now just to annoy me)
Posted : 15/04/2011 7:06 pm
molgrips
This is one of the flaws in ALL studies of helmets and head injuries. Along with no allowance for risk compensation and no allowance for the injuries exacerbated by helmets thru rotation - which is not just neck injuries but a type of brain injury called diffuse axon injury - a very nasty injury. How prevalent this injury is is very debatable - LHS of this forum says it is negligible whereas some researchers state 30% of all brain injuries to helmeted riders are caused in thai manner.. This may be one of the explanations for the fact that as helmet wearing rates increase head injury rates do not decrease along with molgrips observation
dekadanse. I suggest you look at the CTC links. Its far more complex than your simplistic analysis.
Posted : 15/04/2011 7:07 pm
Thank you awhiles
One of the things that is clear the more you read up on this is how poor, biased and limited much of the research is
Posted : 15/04/2011 7:08 pm
 DrP
In the vast majority of cycle crashes, both road and mountain, the bike had a saddle.
Ergo, I've taken my saddle off all my bikes, for safety like.....
DrP
Posted : 15/04/2011 7:09 pm
I couldn't care less about experts or the law, until the idiots that are driving about everywhere, learn how to drive safely, I'm wearing a helmet!
Posted : 15/04/2011 7:13 pm
Posted : 15/04/2011 7:15 pm
Posted : 15/04/2011 7:16 pm
Posted : 15/04/2011 7:25 pm
Came off Wed night at Inners. Over the bars. Helmet severely bashed and lost skin off arm/shoulder.
Helmet certainly saved me from worse injury. No question IMO.
Posted : 15/04/2011 7:32 pm
I had a big off last year. Upright at 20 to on my head and stopped. Knocked myself senseless (or out) apparently.
If I'd been wearing a helmet I'd be claiming it saved my life. I wasn't.
Posted : 15/04/2011 7:35 pm
TJ, If people need a comforter in the form of an overpriced hat to ride a bike then let them get on with it.
Posted : 15/04/2011 7:40 pm
Dekadanse, I presume you wear a helmet for all day to day activities as that is the logical conclusion of your view.
Posted : 15/04/2011 7:45 pm
I've also had some shocking crashes and am certain my lid has saved me from more serious injury, I wouldn't ride on or off the road without one but it's personal choice.
I also don't understand how people can ride (on the road mainly) while listening to music on an iPod/etc but they do.
Posted : 15/04/2011 8:02 pm
Slightly OT but while on a driving speed awareness course (where you can dodge the three points) it was pointed out that the human body is designed to crash at speeds up to 20mph, because that's about as fast as we can run. So surely if you are going over 20mph (more likely on a road bike for most) and come off chances are you'll hurt yourself pretty badly so a helmet will help?
Going off road of course you have the bonus of rocks and trees to hit yourself on.
Not sure what point I was trying to make there but I still wouldn't ride without a lid.
Posted : 15/04/2011 8:08 pm
What a stupid argument I really don't know why you waste time on it TJ.
How are you going to conduct a conclusive study that helmets don't help prevent serious injury? Get a bunch of people, some wearing helmets, some not, then subject various parts of their bonces to blunt force trauma? See which ones sustain the most/least injuries?
No. Which shows how flawed any 'research' is. My own 'research' conclusively proves that all those wearing helmets did not sustain more serious injuries.
Good enough for me.
Posted : 15/04/2011 8:15 pm
You might not have knocked yourself out, however. Had you considered that?
Anyway you've posted some utter rubbish on here recently. You sure you ain't sustained lasting damage? 😉
Posted : 15/04/2011 8:17 pm
I don't know why the "helmet saved my life" brigade get all aggressive about this. No one, including TJ, is advocating not wearing helmets. Read the studies, listen to anecdotes, do your own risk assessment, make your own decision and take responsibility for it. I'd much rather we had the choice rather than leaving it up to some self important politician and the nanny state to legislate compulsory use of helmets.
I entirely respect those who choose not to wear a helmet on the road because the stats are ambiguous. Personally I wear one.
Unfortunately I doubt there's any data for helmet vs no helmet deaths off road because its probably very rare anyone MTBs off road without a lid. So in the absence of any stats on which to base an informed decision I've done my own risk assessment based on my judgement of the likely frequency of falling off combined with the chances of hitting a solid object and wear a lid off road as well- (I bet TJ does mostly too). I judge the probability of falling off off road to be so high I happen to think anyone not wearing a lid offroad is mental and would not ride with anyone not wearing one but if they want to feel the wind in their hair, realise that any head injury they sustain may well be worse without the mitigation of a helmet and they take responsibility for that decision then its up to them.
Posted : 15/04/2011 8:18 pm
For MTBing and skiing death from head injury is rare enough to make a protective effect of a helmet difficult to show conclusively in a trial. But for skiing the evidence is pretty clear now it reduces the severity of lesser head injuries. I don't think enough real MTBers don't wear lids to do a sensible trial now.
On a road bike I think the impact speed and risk of multi-trauma/crush related death makes a helmet much less protective.
Anyway - I am now on a new helmet after I used my head and face to slow down at Swinley 3 weeks ago. I needed a Fire Brigade land rover, an Ambulance and a CT scan - and a few days off. But I'm nearly normal again and as long as I am in the trees, I'll be lidded up.
Posted : 15/04/2011 8:24 pm
Are we? Or is the perceived 'aggression' all in your head? Hmm?
What are the voices telling you today?
Elfinsafety
kill them allllllllll, inflicting massive rotational injury in the process......
Posted : 15/04/2011 8:28 pm
I discussed it with a guy who saw the crash. I think the knocked out/senseless was caused by my neck, or my body try to rotate round it. I remember the sensation clearly. The other guys comment was "if you'd been wearing a helmet it would have dug in".
So, yeah, maybe a helmet would have helped and I'd be saying it saved me. Maybe it would have broken my neck and I'd have been saying how much worse it would have been if I hadn't been wearing a helmet.
Who knows?
One things for sure, it's amazing what you can get away with and I'm not convinced "the helmet saved me" stories mean very much.
Posted : 15/04/2011 8:36 pm
 WTF
I came off my bike with a helmet and once ages ago without a helmet.
First one I smacked the side of my head off the kerb which resulted in concussion for an hour and a sore head ,second one resulted in a smashed helmet and broken ribs.
No concussion or sore head.
I`ll keep wearing one ta.
Posted : 15/04/2011 8:37 pm
Did anyone suggest you shouldn't?
Posted : 15/04/2011 8:39 pm
How are you getting on with the pressure suit?
Posted : 15/04/2011 8:40 pm
 WTF
Not personally but the premise of the thread is that wearing one is neither here nor there ?
Once upon a time, during a summer Polaris, in Northumberland, me & my mate were bombing down a fire road. I've got the map on a board on the bars & was looking to see where the next turn off was. Suddenly (& without warning) my mate slams his brakes on. There in front of me, was a single bar gate across the track, weathered so that it was fairly inconspicuous. I'm doing maybe 20ish mph & before I had time to think 'bunny hop' I'd got my arse over the back wheel & it was 'Brace for Impact' I hit the gate with the top of my head, ended up on my arse in the gravel with a cracked lid with either Sparrows or Baby Robins circling round my bonce going 'tweet tweet tweet'
I'd also slammed the anchors on but it stil fu**ing hurt.
Until the 'experts' prove otherwise, I'll be wearing mine.
Posted : 15/04/2011 8:41 pm
Ok. I'll smash you in the head with a hammer, equivalent to the force which managed to crack my helmet. We can try it with a helmet, and without. That's proper scientific, that is.
Up for it?
Posted : 15/04/2011 8:42 pm
Why use a hammer? You could sit on my helmet and break it.
That's not a come on.
Posted : 15/04/2011 8:45 pm
Oh you're saying I'm fayt now, are you?
Well that's marvellous, that is, isn't it? 🙁
Posted : 15/04/2011 8:47 pm
Again all the studies will be essentially be based on accidents that happened on the road where there is a greater mix of helmet vs non helmet wearers and have little relevance to off road cycling where most people wear a helmet and there are (probably) much fewer casualties. Therefore I see no point in getting all defensive and quoting anecdotes about your MTB antics. I doubt anyone is going to be proving helmet use is a good or bad thing off road anytime soon so relax.
Posted : 15/04/2011 8:52 pm
i can completely understand how a heavily vented helmet could twist your neck etc from say a strong branch snagging.On balance though I know I will always wear one.Plus they will keep being improved too...
Posted : 15/04/2011 9:01 pm
[i]all the studies[/i]
I really don't get all this 'studies' business. Why not just go for facts. IE ask people who were, or weren't wearing lids when they had a pile up & ask, 'are you pleased you were/weren't wearing a lid?' I'll bet you'd get. 'Yes, I'm pleased I was wearing one', or, 'I wish I'd been wearing one', & not, 'I wish I hadn't worn my helmet', except in the very odd circumstance. (bit like, 'well the car was on fire & I couldn't undo the seat belt, so i wish I hadn't had it fastened')
Posted : 15/04/2011 10:23 pm
I had a big high speed off head first into some sharp pointy rocks a few years back. Now I'm not saying that the helmet saved my life, but it sure as hell stopped me losing half my scalp...
Posted : 15/04/2011 11:13 pm
I always wear a helmet, it makes me feel better about riding.
However I was in belgium a couple of weeks ago. everyone rides a bike, and i mean EVERYONE. no one wears a helmet, literally no one. I didn't see piles of bodies, or queues outside hospitals with head injuries. I t definitely made me think about why there is such pressure to wear a helmet in the UK.
Posted : 15/04/2011 11:25 pm
I just like to wear a great big DEJA VU on my head.
Posted : 15/04/2011 11:35 pm
It all kicked off, and as usual TJ was/is right about helmets. The problem is most of those arguing against him ascribe views to him which he doesn't seem to hold...
...so, same old, same old really!
Posted : 15/04/2011 11:43 pm
Just thinking about all the "my helmet cracked" an "I split my helmet In two" comments....
Arent lids supposed to compress and deform in the event of an impact rather than split? If they split have they have failed to absorb the force of the impact properly and therefore "Failed"?
Posted : 15/04/2011 11:46 pm
Ta peyote and others who understand
I wear one night riding, usually but not always riding in groups and almost always at trail centres, riding around on easy trails and quiet roads I don't
Note the huge hazards all around, rock gardens, huge dropos, fast traffic - must wear a hat
[url= http://farm4.static.flickr.com/3287/2533134153_2a0eba756d.jp g" target="_blank">http://farm4.static.flickr.com/3287/2533134153_2a0eba756d.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/25846484@N04/2533134153/ ]05 Glen Dochart[/url] by [url= http://www.flickr.com/people/25846484@N04/ ]TandemJeremy[/url], on Flickr
Posted : 15/04/2011 11:54 pm
twohats - Member
a ensible answer.
Posted : 15/04/2011 11:55 pm
Its also worth noting that the only times I have ever hit my head I have been wearing a helmet. Got my risk assesment right or helmets make you hit your head?
Posted : 16/04/2011 12:04 am
 mlke
There's always going to be stories on a mountainbiking site of "I'd have died but for my lid"
We need to find a site called Fatknackerworld in which posters report "if only I hadn't been put off cycling by the false perception that it was dangerous, then I wouldn't have diabetes/heart disease/bottomthesizeofaplanet"
My mother fell of her bike when she was 8 1/2 months pregnant with me. Neither of us were wearing helmets. I think that explains a lot
Posted : 16/04/2011 12:39 am
I was told, after a big road crash, that I owed my life to my helmet, by various doctors and other healthcare people. Which is awesome, because it was at home when I crashed. Surprising how far the protective effects reach!
esselgruntfuttock - Member
Tell you what, why not look up the word "fact" and also while you're at it "opinion". You've not managed to post any of the former.
Posted : 16/04/2011 1:19 am
TandemJeremy - Member
Is it awful that I chuckled at that?
Sorry, TJ! 😉
Posted : 16/04/2011 2:50 am
5thelephant
On the subject on neck injury (something I have had some experience of)
When the dr refers to injury being passed on to the neck I believe he is talking about rotational, in that the head is forced backwards or forwards and over extended in either direction (as opposed to being turned to the left or right along the spinal axis)
My understanding is that This hyper extention is the problem to avoid.
In my case: over extention forwards by impact on the top back of the helmet caused minor brain injury with major spinal trauma. With the helmet off: mostlikely dead.
If the choices in a serious crash are paraplegia or brain damage, there isn't much in it.
In a less serious one whiplash (with a hat) or concussion/minor brain damage/chunk of scalp missing (without hat) I'll go for whiplash thanks - you get to ride back home and than take Monday off work 😉
I'll still wear my helmet. .
Posted : 16/04/2011 7:09 am
I should probably add that the bar end hit me in the back of the head. But would have prolly gone right through it had I not bean wearing a lid.
Posted : 16/04/2011 7:26 am
I've suffered servere neck injuries twice from crashes whilst riding, were they caused, or at least worsened, by
wearing a helmet? Possibily? Possibily not? How can you ever know?
What I do know is that I've whacked my head on countless trees, hit rocks with my head and on one occasion written off a helmet by crashing and having the bike flip over on top of me and leave a whole line of chain ring teeth 'indents' in the helmet.
None of the above incidents left me with ANY head injuries. That's research in my books.
The other thing I'm interested in is for all of those who are suggesting that the wearing of a helmet could cause more injury and perhaps isn't the be all and end all that people like myself choose to believe it is, well, what do you do? Have any of you actually stopped wearing a helmet whilst riding???
Posted : 16/04/2011 7:29 am
is a sensible nuanced view.
Posted : 16/04/2011 8:14 am
A helmet having split still deforms and absorbs energy.
Anyway. Do the words 'just in case' not mean anything to the part-time helmetters?
And don't think pootling down the shops is necessarily safe. On the trails, most things are within your control. On the roads, most of the hazards are way beyond your control.
So far, you've been lucky 🙂 Any day a car could cut you up and force you into a fence or tree or something.
Posted : 16/04/2011 8:56 am
Elfinsafety:
Elfinsafety:
Up for it?
I would say, on balance, the aggrssive nature of the helmet saved my life brigade is not imagined.
Posted : 16/04/2011 9:23 am
So molgrips - pressure suit at all times? helmet when drinking beer / driving a car/ getting out of the bath?
Can I just repeat that the rotational injury from helmets is not a neck injury - its a type of brain injury known as a diffuse axon injury. In the stats it is usually assumed if you get one of these it would have been worse without a helmet but some researchers believe it would have been less without a helmet. Its one of teh potential reasons why there is no reduction in head injuries seen as helmet wearing rates rise
Its a poorly understood area where more research is needed. Teh effect is there how prevalent is hard to know.
http://members.pcug.org.au/~psvansch/crag/h-i-mech.htm
http://www.chapmancentral.co.uk/wiki/Assessment_of_current_bicycle_helmets_for_the_potential_to_cause_rotational_injury
http://cyclehelmets.org/1182.html
http://en.wikipedia.org/wiki/Bicycle_helmet#Rotational_injury
Some manufacturers are now working on helmets to reduce rotation. There is a disadvantage - increase weight complexity and cost
http://www.mipshelmet.com/how-it-works
http://www.phillipshelmets.com/
Posted : 16/04/2011 9:26 am
Teh point of this is to show that the protection from serious injury by cycle helmets is overstated, not that you shouldn't wear one but that you should make informed choice and rather than be arguing for compulsory helmets be arguing for better testing and design of helmets
The other aspect is serious head injury is rare. the odds are low and I for one can happily live with a million to one chance.
So - I wear one when the odds are high - trail centres and the like for eht protection from minor injury, I don't wear on when the odds are low of crashing and I don't expect one to protect me from major injury
Posted : 16/04/2011 9:34 am
I do the same.
I ride differently wearing a helmet too, although that's quite minor.
I'm the same on a motorbike, obviously I have to wear a helmet, but when weather permits I wear shorts and t-shirt. Compared to wearing my usual full leathers I'm at much less risk as I'm going 80mph slower. There was a lot on this phenomena in the motorbike press a few years ago and many of the journos swapped to riding in jeans. Risk compensation is a big killer on motorbikes. I doubt it's noticeable on bicycles as the speeds are so low though.
I'm pretty sure a 10" spike sticking out of the centre of the steering wheel would reduce the death rates for young drivers.
Posted : 16/04/2011 9:44 am
I am sure risk compensation is a factor. You feel more vulnerable without a helmet and ride more carefully
Posted : 16/04/2011 9:47 am
Risk compensation is the very reason I wear a helmet, im more likely to try something borderline with it on, and I generally get away with it.
My percaption of risk stops me doing something I want to do, wearing the lid is a way of overcoming the fear.
Its probably for the best that I dont wear one on the road as If I take more risks there im more liable to get squished by a car.
Posted : 16/04/2011 11:49 am
I'm not sure about risk compensation, for myself at least. I remember I went through a period of crashing a lot on rides and I thought I might be risk compensating because I was wearing body armour. So, I tried a ride without it and still crashed just as often but with a nasty friction burn on my arm and a shin that was steadily leaking blood into my shoe. I don't think wearing a helmet makes me more likely to crash either since I'm not even aware I'm wearing it most of the time.
Where I do think that risk compensation can come into it is with drivers. From talking to none cycling drivers and my experiences on the road I honestly think drivers are likely to take more risks with your life if they see you wearing a helmet than if you don't. So if I'm commuting I don't wear a helmet or wear gear that makes me look like a 'proper' cyclist.
In every other situation I'd wear a helmet.
Just as an aside, on the way to the pub a few years ago, a friend of mine decided to jump on another friends back. Caught by surprise, he stumbled forward which turned into a run which turned into a trip which meant the first friend ended up going head first into the corner of a kerb. It was a really sickening sound but surprisingly enough, apart from some concussion, he was alright. I often wonder if this was bike related and he had been wearing a helmet he would now be saying the helmet saved his life.
Posted : 16/04/2011 12:30 pm
 GW
Molgrips - do you wear a helmet when you walk to the shops, or drive? best stay in the house with a tinfoil hat on all day for fear of anything beyond your control happening.
Helmets are ****ing horrible to wear, even the very best are still hot sweaty and uncomfortable. think I've worn one 3 times so far this year, I used to dirt jump without a helmet but with knee pads and gloves as that's what you land on when you bail so I'm not about to start wearing one riding local XC, out with the kids/family or going to the shop.
Posted : 16/04/2011 1:00 pm
Why are you bringing that up again? It's about risk vs inconvenience. The inconvenience of a cycle helmet for me is easily outweighed by what I consider the safety benefits. End of story.
PS I don't wear a helmet when driving, but I do wear a seatbelt and buy cars with 5 star safety ratings and lots of airbags.
The biggest issue though is things beyond your control. I might ride slower without a helmet but I doubt the driver who hasn't seen me will t-bone me any slower.
Posted : 16/04/2011 1:06 pm
