Dialled Alpine owne...
[Closed] Dialled Alpine owners
[#2089859]
How long is the headtube ?
Posted : 15/10/2010 10:08 am
please hold....
Posted : 15/10/2010 10:10 am
90mm on the 15.5"/16" frames and 100mm on the 17.5"/18" frames.
Edit: maybe the Mk1 frames had 5mm longer head tubes (memory failure/old age), so 95mm/105mm.
Posted : 15/10/2010 10:11 am
105mm?
105mm
original model, not sure if Mike change it on later frames, i remember talk of shortening head tubes when i rode the proto in the Alps
100mm MK2 18" frame.
I dont actually know that, but mike says so ^^
Posted : 15/10/2010 10:25 am
 hora
Why not try the new PA frame? CEN makes it built burly-enough and as far as I can tell only the Alpines seat/top tube brace along with more clearance are the differences..
Posted : 15/10/2010 10:30 am
Alpines not going anywhere, but maybe swapping forks about.
Posted : 15/10/2010 10:31 am
Geometry is different, Hora (Alpine has slacker head angle) and Alpine rated for longer forks.
Scruff's already got an Alpine.
And I LOVE it.
Posted : 15/10/2010 10:32 am
That, dear boy, speaks volumes of you
Posted : 15/10/2010 10:35 am
 hora
Oh yes and the head angle and that forky-bit.. 🙄
..anything else? 8)
Posted : 15/10/2010 10:40 am
Alpine is basically a harder hitting, longer forked and slacker frame than the PA. I suppose if you wanted to pigeonhole it, you'd stick it in with the likes of the BFE, Blue Pig and 456 Summer Season.
Prince Albert was reverse engineered a little bit when I changed from 520 to 725 tubing to make it less burly. It's probably a bit harder to pigeonhole these days because it's not as light/XC as an Inbred or Soul but not as burly as the frames mentioned above. Probably falls somewhere between the Soul/Inbred category and the BEF/Blue Pig/456SS/Alpine category.
Posted : 15/10/2010 10:47 am
If only you'd asked last night. I had a tape measure in the car. You could have measured it.
Posted : 15/10/2010 11:06 am
What is the Alpine like for climbing? Do you need to wind the forks down or is that not required.
I'm seriously tempted by an Alpine but I'm not sure if it is different enough from my MG to justify getting one.
Posted : 15/10/2010 11:09 am
I have a relatively short stem on mine, the shorter headtube on the MKII will help. I've got used to climbing on it, it's not the easiest but travel adjust forks would help a lot (i don't have them). On the other hand, once you are used to the slightly skittish steering on climbs and have masterd popping the front wheel up and over stuff it becomes a lot of fun. Now my bike of choice for riding in the peaks and lakes on rocky stuff
point it downhill however and everything just becomes a blur of speed and smiles
Posted : 15/10/2010 11:12 am
Mine climbs fine with 60mm stem and 140mm Revs, dont feel the need for winding down on climbs. I've just put lower wider bars on and front ends feels more planted up and down, which is a bit weird. Alpines are stiffer and handle better (more *GRRR* ) than an MG but not as comfy.
Posted : 15/10/2010 11:17 am
What forks are you getting Dad?
Posted : 15/10/2010 11:19 am
I've never really hung about after the ride on a Thursday, if it involves BigJohn measuring other peoples tubes then I'm pretty glad of it.
Posted : 15/10/2010 11:23 am
Thanks for the responses.
I'm currently using Pikes on the MG and have them at 140mm most of the time so I'm not sure there is really going to be that much difference between that and the Alpine, unless I get some bigger forks for it too.
However having recently moved to the Highlands the ability to have a bit more GRR may be justified 🙂
Posted : 15/10/2010 11:24 am
Alpine will be excellently suited to epic highland passes, the rocky ones that look like you could never ride down them, it is after all designed for riding steep rocky trails in the Alps. I've ridden a few things in the Peaks on the alpine that i've balked at on other bikes
Posted : 15/10/2010 11:26 am
Pikes on Alpine is just right IMO for non-specific-category riding, it will be slacker and lower and better for *Aggressive XC Grrr riding*- depends what you want really.
Posted : 15/10/2010 11:31 am
 hora
Be interested to know where these are/anything new?
I've ridden most things in the Peaks on every frame I've had recently (456, Blur4x etc)
Posted : 15/10/2010 11:34 am
some of the more direct lines down Cut Gate and the Beast mostly. You can cut out some of the Cut Gate hairpins with 'Alpine' style roll downs, nads on the nobbles kinda thing.
Posted : 15/10/2010 11:36 am
 hora
Have you been down Parkin Clough? (its cheeky mind).
Hoping to ride Edale-Mam Tor-down Cavedale-then up and over Mam old road and down Chapel Gate early tomorrow am 🙂
Posted : 15/10/2010 11:39 am
I swapped from a 456 to an Alpine and found it much better. Partly a slightly more sprightly ride (yes, really), partly the angles just seem to work better. I dunno why, but it's a bike that instills confidence somehow.
I found it better climbing with a slightly longer stem (80mm) with no change in what it was capable of. Preferred to run at 125mm with the option to open up to 140 for descents. Sadly I'm gonna flog it shortly due to back surgery - if I can ride again I'll be looking at a PA or maybe a Soul.
Posted : 15/10/2010 11:41 am
don't do cheeky in the Peaks
Posted : 15/10/2010 11:44 am
Hora- yes. Dismounted for two sections.
Posted : 15/10/2010 11:45 am
I've got a PA at the moment but i'm very Alpine curious, they just look right. If i changed over it would be run singlespeed though.
Anyone else do this? Or am i missing the point a bit?
Posted : 15/10/2010 11:52 am
SS + 80mm stems + 125mm forks = Blasphemy.
Posted : 15/10/2010 11:54 am
 hora
Scruff, the only way I can see dismounting there is down into that stream or over the bars 😆
Im 5' 8" an ride the new small model Alpine with Pikes and find it to be a great all round trail bike. For me the big selling point is the dropped top tube design as it has LOADS of standover clearance. The angles seem "spot on" and its relatively cheap compared to many other frames. Some people say its just for "big stuff" but I find it great for general riding and having fun on 🙂
Posted : 15/10/2010 12:06 pm
Rich S - let me know if you do consider selling your Alpine - if its an 18 that is
Posted : 15/10/2010 12:11 pm
Whoa, i didnt say anything about the 80mm stem and 125mm forks. 😉
It would be run properly pikes and a 50/60mm stem 😀
Posted : 15/10/2010 12:12 pm
top frame.... very happy with mine after a season in the alps. will be ragging it around Gran Canaria next week for six months.
woo-and indeed-hoo!
Posted : 15/10/2010 12:16 pm
Yeh class frame thats good for downhilling in the alps.
Posted : 15/10/2010 12:17 pm
 GEDA
Think my Alpine is 140 pike forks and 80 stem. I love it though. I had a 50mm stem on my PA though but it has a longer headtube. So stem length is more to do with the frame than anything.
I never wind the forks up or down. My best bike.
Posted : 15/10/2010 12:50 pm
i should say that i have 150mm air forks which have the small bump sensitivity of a brick, this slightly slacker head angle and lack of fork preload will make it completely different to those with 140mm coil forks.
Posted : 15/10/2010 12:52 pm
 ojom
Thoughts please:
Ti Alpine... how many of you would be interested if said mythical beast were to exist?
Posted : 15/10/2010 1:00 pm
mangoridebike - will do. It's the old version but is big/long - 17.5" with 23" TT. The new one is 1/2" longer in both dimensions IIRC.
Posted : 15/10/2010 1:03 pm
bikechain - several people across the country have just done a sex wee in their pants.
I believe Mike has pondered this before
Posted : 15/10/2010 1:06 pm
 hora
Ti Alpine
Mike, hello 🙂
Posted : 15/10/2010 1:08 pm
i would buy one
Posted : 15/10/2010 1:09 pm
I have a Mk 1 PA and am Alpine curious also.
Anyone recall the weight of the Mk1 frame. As I occasioinally enter an enduro type race and like covering some miles [but also like my trips to Gawton and only want 1 bike] I keep thinking a lighter frame would be nice, but I want the angles of the Alpine.... At 5.5lbs for the current Alpine, it's never going to be lighter than the Mk1 PA, or is it?
Am I a confused individual?
Posted : 15/10/2010 1:17 pm
Yes...I am niche-tastic.
