di2 junction box or...
[Closed] di2 junction box or bar end?
Just speccing out my new build. Is it worth going for the bar-end ports or sticking with the usual 3-port under-stem thing?
Posted : 09/03/2018 6:26 pm
 SamB
I've just upgraded from a 3-port to the bar end. It's a bit of a faff to fit, but it's SO much neater in use. Definitely worth the change if it isn't much more expensive.
Posted : 09/03/2018 6:29 pm
I think it’s about 5 euros difference. I need to check with the guys at r2-bike that they have given me all the right cables.
On the subject, if I want to use the app to change settings do I need that Bluetooth/ant component?
Posted : 09/03/2018 6:39 pm
Bar end plug is every time.
for blue tooth you need WU-111 and the newest seat post battery
battery should be less of an issue on a new build just a problem when upgrading older bikes
Posted : 09/03/2018 6:45 pm
I wouldn’t change a bike already set up, but if building new I would go for bar end every time.
Posted : 09/03/2018 7:14 pm
Yeah, it's a completely new setup
Posted : 09/03/2018 7:17 pm
