DHX5.0 coil setup q...
[Closed] DHX5.0 coil setup question...
 sv
The bottom out adjustment can only be set with the boost valve setting at 125psi or below but after adjusting it can the pressure be increased again?
Posted : 10/12/2010 12:04 pm
 LoCo
Yes, factory setting is 150 psi, generally what works best. Generally you'd run the bottom out fully out too.
Posted : 10/12/2010 12:07 pm
 sv
Asking myself why I didn't just email you directly! You will be servicing this shock early next year once I pay of Christmas bills ๐Ÿ˜‰
Thanks Simon.
Posted : 10/12/2010 12:15 pm
