DHX Air 5.0 and Pro...
[Closed] DHX Air 5.0 and Prophets what air pressures
how heavy are you and what pressure do you use? I have to put nearly 200 psi(the recommended max) to get the correct kind of sag, I'm only 88KG ๐Ÿ˜€
Posted : 01/04/2009 4:01 pm
What year of shock?
Max pressure is 300psi is it not?
Posted : 01/04/2009 4:04 pm
๐Ÿ˜ณ doh, its 2006 but your right I was looking at the boost valve settings
Posted : 01/04/2009 4:10 pm
