Evening all
Long shot but here goes.
Seems my mech hanger / dropout adjuster / frame might be ****ed ๐ฅ
The circled little adjuster in the pic stops the dropout insert spinning when you tighten the maxle and also pulls the mech hanger flush with the frame. Mine however won't tighten, it just spins and as a result the maxle won't tighten and the mech hanger isn't pulling against the frame.
Can anyone tell me if the hole on the little adjuster has a thread and is is perfectly round as mine is thread less and slightly oval. Also is the hole in the frame threaded as this is bare also.
I can get a new adjuster and mech hanger if need be but I really need to know if the hole in the frame is supposed to be threaded as well, as if so it means it's stripped ๐
I hope this makes an ounce of sense, was supposed to riding tomorrow and I have a trip to snowdon next weekend
Hope you can get one by the weekend ๐
J E James have the parts in stock as ive just replaced all my re dropouts on my G150 , Make sure you check as they have two listed ,Sram and Shimano
No the frame isn't threaded just the back side mount and screw
http://www.jejamescycles.co.uk/whyte-t-129-s-m109-m109s-g150-mech-hanger-sram-id77383.html
http://www.jejamescycles.co.uk/whyte-adjuster-clamp-m109-t129-g150-drive-side-id79896.html comes with screw and lock tight on it ๐
Hope im not braking any rules by linking just trying to help out
As a side note, was the little stopper threaded?
Wonder if it was done up too tight?
Im sure they had the stuff in the Rotherham W/house as that's where I rang ,and no the stopper isn't threaded just the screw and rear mount
legend,
Seems a bit of a weak spot actually, for saying it is only a tiny screw on a high load part.
Can you collect stuff from the Rotherham warehouse?
Only holds the mech hanger in place. No real load through it.
You can't collect from je James warehouse, just the stores.
