Definitive all-roun...
[Closed] Definitive all-rounder dynamo front light?
Does it exist?
Needs to be:
Crown-mounted
Good for quick commuting and also off-road at moderate speeds
Weatherproof (so no USB charge port)
Not silly money (under a ton)
With decent buffer/standlight
Posted : 08/03/2017 2:09 pm
 aP
I have a Busch and Mueller Lumotec IQ Cyo 40 lux lamp on my Brompton, its done a year now and is still going ok. I did run it on the sense setting, but just leave it turned on all the time now.
Posted : 08/03/2017 2:18 pm
I'm not sure your two objectives are really compatible.
I've got a B&M Lumotec of some form on my Brompton. It's good enough to make your way across an unlit park on a commute but I'd not want to ride singletrack on it. My Canyon commuter has a Supernova E3 which is significantly brighter.
Both have properly shaped beams which mean they don't dazzle oncoming traffic (or other cyclists - nothing worse than someone coming at you on a two way path with some blindingly bright flashing monster) and they use the light effectively. Both are more than enough to be seen.
Off road your requirements are different - you want to throw more light upwards and outwards to read the trail and spot any low branches.
Posted : 08/03/2017 3:18 pm
 aP
Simons has a fair point, the cut off is quite distinct.
Posted : 08/03/2017 3:47 pm
 scud
From all i've read Exposure Revo or K-Lite from Travers for off road usage, and the B&M for road usage.
Posted : 08/03/2017 3:50 pm
Agree with the above, the peeps who ride with lights brighter than a car at full beam are super obnoxious
Posted : 08/03/2017 4:00 pm
BM IQ Premium is 80 Lux.
No USB port and weatherproof.
Ok offroad on simple stuff, but anything techy and I put an Aldi special on the bars.
The cut off is a bit limiting otherwise.
Posted : 08/03/2017 4:34 pm
Good points re differing beams/intensity. By 'offroad at moderate speeds' I mean if I get caught out down a farm track or across a moorland rupp then I can probably get home without going at walk-speed, neither plunging over a quarry.
Already have an X2 unit for pure off-road but it's assentially a rough-road/back-lanes touring bike that will be getting the PD8 setup. Had a quick gander online at B+M lights but the choice seems extensive!
Posted : 08/03/2017 5:26 pm
Confusing, innit?[url= http://www.longleafbicycles.com/pages/decoding-busch-muller-model-names ]
This [/url] seems to give a good explanation of what everything means.
Posted : 08/03/2017 6:03 pm
SON Edelux 2 perhaps. Very happy with it after owning one almost 3 years, road and open tracks kind of use, handles a bit of singletrack better if you use a bar mount as a back up but is OK without (watch those branches). Can also be angled up a bit when off-road if needed.
Now have a rear SON plugged into it and it's a great system. One switch controls both lights.
Posted : 08/03/2017 6:27 pm
For riding on road the German lights are much better than off road lights. The reflectors are really well designed *but* they're not all the same - look at the beam patterns on the Edelux lights on here
https://www.nabendynamo.de/produkte/edeluxii_en.html
Yet another example of where 'regulations' and 'red tape' deliver really useful results. So many lights sold in the UK are shit. https://medium.com/@charlesarthur/the-herald-of-disaster-or-why-you-should-welcome-regulations-fbaaeaed17e5
Posted : 09/03/2017 12:33 pm
