Dartmoor Primal 29'...
[Closed] Dartmoor Primal 29'er. 2016 Frame (I think!)
 benz
At ~ £100 recently, a new frame was too good to miss.
Build up with 130mm travel Fox, 1 x 11 SLX, MT35 wheels tubeless, etc.
It rides really well, but now fancy a dropper for it.
So....does anyone else have one, and is it an externally routed dropper post I need?  I can see cable hole on the seat-tube - which I suspect is for front mech cable - if you run one, but it looks like it will still require a lot of external cable for a dropper...but I could be wrong!
It is the frame with the 'swoopy' top-tube, a bit like an On One Parkwood 29'er...
Thanks!
Posted : 06/12/2018 2:12 pm
If its a hole it will be for dropper. front mechs use a little stand off outer cable end.
Posted : 06/12/2018 3:36 pm
I had one and it had an Internal Dropper
Posted : 06/12/2018 4:41 pm
