Damn - lost a beari...
[Closed] Damn - lost a bearing spacer/washer - where to find a new one?
I have been replacing all the frame bearings in my Intense Tracer 2 and have managed to loose a bearing spacer (I think this is the correct term). I have no idea where to find one. It had inner diameter 14mm, outer diameter 18mm, depth 3mm and seems to be made of aluminum.
Any Ideas where I could find such a thing?
Posted : 16/04/2015 8:18 am
Maybe try Extrauk.co.uk?
They are the UK distributor for Intense
They helped me when i lost a bolt
Posted : 16/04/2015 9:27 am
have you looked under the fridge?
Posted : 16/04/2015 9:28 am
If you can measure one I should be able to knock one up for you. I may also have a spare as I replaced all mine when I made my new linkage.
Posted : 16/04/2015 10:04 am
Extrauk.co.uk
Thanks for that
slightly annoyed now I ordered the bearings from the US
They have a part which could be right one but helpfully no images
Posted : 16/04/2015 10:09 am
stevied
ID = 13mm, OD = 18mm, depth 3mm
These are approximate and the actual dimensions could be imperial
I'm still trying to find my verniers
Are you Malvern based? (I am Worcester)
If you could help me out I would be eternally grateful ๐Ÿ™‚
Posted : 16/04/2015 10:13 am
If you have an original one and are in Malvern around 5.30 I could check yours against one of my spares? Drop me an email if interested: steve_dees @ hotmail.com
