Bit of a thread resurrection but I was doing a search for this kind of stuff and this came up.
I've been running a RF narrow wide 42t with 11-32t and against all advice an Ultegra medium cage mech all summer for training. I've been over some pretty bumpy trails but not had one chain drop, with no chain guard. I'm going to be racing on this set up soon and I'm starting to have second thoughts on a) ruining my nice Ultegra mech and b) medium cage in't going to cut it in the slop.
I was looking at two options 1) cheaper 105 11 speed short cage mech and hope it fits my 11-32t (should do with 1x11 setup) or 2) more expensive getting the new XTR 11 speed clutch mech. Does anyone know if this will work with Ultegra 6800 road shifters?
[b]pixelmix - Member [/b]
Please do barrykellet.Birdage - your experience sounds positive, but I see you are running an n-gear jump stop. Are you not running a bash? I'm keen to lose my bash as I find that mud gets jammed between bash and chainring in really muddy, grassy races. Hmm, maybe I should leave the n-gear as a fail safe on the inside, even with a narrow/wide chainring.
First race yesterday.
Worked flawlessly for the majority of the race, and a very fast race too. Didn't miss a bigger ring at all. 38t was plenty for it.
Unfortunately in my battle with one guy, he was hopping the boards and I was running them, big time to be gained or lost there. Tried to recover the gap on the last lap and as we came together he nipped ahead of a lapped rider and I got stuck. Gave it all my beanz after getting past and launched a roll down at full pelt, the landing was rough, the chain came off!
Rider error. Lost 8 seconds of stopped time plus whatever time getting back up to speed. Wouldn't have happened with a Clutch mech on there to be honest so I am a bit peeved. Think I will give it another chance. maybe fit a chain catcher on the inside to halve the possibility? Though if it is dropping off I guess a chain catcher will just stop it going inside and push it off the outside instead?
To be fair, you don't know that. An N Gear Jump Stop (or similar) will help if it's coming off the top, but if it's doing that then a clutch won't really help either - that's only adding tension on the bottom run of the chain after all.
Well, in theory, it tensions the whole system doesn't it? if you pull the bottom run then the top run should be similarly tensioned. The issue in a crash is that you can spin the cranks/etc quickly enough to loosen the tension for a short moment but possibly long enough to unship the chain.
njee20 - MemberTo be fair, you don't know that. An N Gear Jump Stop (or similar) will help if it's coming off the top, but if it's doing that then a clutch won't really help either - that's only adding tension on the bottom run of the chain after all.
I suppose I don't know for sure, but I have had a narrow wide + XT clutch on the XC race bike all year and hit a lot of things a lot harder than I hit that.
Will browse the usual places for a pair of SRAM Apex or Rival shifters for as cheap as I can, and until such times just use the set up as is. I was only ever competing for a top 10 placing so I certainly didn't lose the race over it.
Wee update.
Seen this:
http://www.pinkbike.com/u/SupraShin/blog/How-to-convert-SHIMANO-Shadow-Plus-RD-into-9-speed.html
And decided to test it out. Stuck a Zee mech on with some cable ties as shown and low and behold, it does actually seem like it could work. Very fiddly and the cable ties I have on aren't really super strong - but I managed to get the thing covering the full 9 cogs out back and reasonably good shifting across the majority of them. A bit of fine tuning using stronger ties and I reckon it will work.
I can't decide whether its a suitable set up for racing though! In my mind it is risky, but are the ties actually under much load?
I discovered that blog entry while looking further into the drilling method linked to earlier in the thread. Perhaps working out the pivot point for the cable using ties could show you exactly where to drill the hole for a more permanent fix?
