Cycling Jerseys: an...
[Closed] Cycling Jerseys: any reason not to use a running jersey?
Just been checking out short-sleeve cycling jersey prices and they seem more expensive than similar quality running jerseys. Any reason not to use a running jersey? I don't need pockets, just a slim fit and good wicking.
Posted : 28/05/2009 10:22 am
cycling jerseys tend to have longer backs - you might find you end up with a gap twixt shorts and top when you lean forward.
Posted : 28/05/2009 10:23 am
As above, running tops may well be too short when in your riding position.
Posted : 28/05/2009 10:55 am
Wear what you want, as long as it's comfortable. But as above - short back and neck might be a bit wide.
Posted : 28/05/2009 11:03 am
football shirts can usually be found quite cheap
[url= http://www.mandmdirect.com/ProductList.asp?SearchString=&Filter=3|Sports|1|Mens|5|Football&AS=true&ProdPerPage= ]MandM[/url]
Posted : 28/05/2009 11:05 am
Hmm ok, that's a pain. The cycling jerseys at my LBS are all £35-40 if you want one that doesn't look terrible. Seems a lot to pay for a polyester t-shirt...
Posted : 28/05/2009 11:06 am
you can get them cheaper than that if you shop around
[url= http://www.stif.co.uk/gear/select_options.asp?productid=6389&store=mtb ]fox jersey at stif[/url]
Posted : 28/05/2009 11:17 am
Rugby shirts are always a good bet - vary in thickness and you can get long or short sleave. You can pick last seasons club shirts up for about £20 a pop and they're generally wicking but hardwearing technical fabrics.
Try [url=www.lovellrugby.co.uk]Lovell Rugby[/url]
Posted : 28/05/2009 11:20 am
they're not that short. i find my ruinning tops just touch the top of my shorts will riding - ok in the heat but not much cop in the cold, the lack of a neck and a zip mean s temp control is not achievable.
also lack of pockets sometimes is an issue.
Posted : 28/05/2009 11:26 am
