Cube DT Swiss EM 3....
[Closed] Cube DT Swiss EM 3.7 csw rear hub rebuild
Anybody got these wheels off a Cube Stereo struggling to find any info on the web trying to replace the rear axel bearings and can't find how to dismantle them our what size bearings they take
Posted : 24/12/2014 4:03 pm
It's either an 'onyx' based hub (2 pawls,needle bearings in a white carrier).[url= http://www.dtswiss.com/Resources/Support/HUBS/DT-Swiss-Hubs-Onyx,-Cerit-Technical-Manual ]onyx[/url]
Or a 240 star ratchet based hub (2 opposing ratchet rings).[url= http://www.dtswiss.com/Resources/Support/HUBS/DT-Swiss-Hubs-240s-Technical-Manual ]240[/url]
Manuals on Dt site.
If it is a star ratchet hub then you'll need a special (and expensive) tool to remove the ratchet ring to get the the ds bearing out.
Posted : 24/12/2014 4:09 pm
Thanks The free hub runs smooth its only axle bearings which feel rough I'm familiar with hope pro 2 which have two bearings on the axle and the free hub removes on one piece is it a similar setup on the Dr Swiss hubs
Posted : 24/12/2014 5:20 pm
Similar-ish.
If it's got push on end caps then it's 240 based.
If it's got threaded on locknuts it's onyx.
Neither are rocket science to service (removing ratchet ring not withstanding).
Posted : 24/12/2014 5:26 pm
Chees rorschach much appreciated
Posted : 24/12/2014 6:29 pm
