crown race removers
[Closed] crown race removers
[#1769174]
anyone bought one of these?
http://www.bikechase.co.uk/index.php?p=160933
I mean this specific one rather than a Park Tools one which looks to be £100 more....
Posted : 05/07/2010 8:09 am
I've got something similar, Ice Toolz I think mine is, works OK on most, not a patch on the Park one, but at the price of it, it shouldn't be!
That one in your link looks expensive though.
Posted : 05/07/2010 8:14 am
I have something like this [url= http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=10223 ]Linky[/url] and it works a treat
Posted : 05/07/2010 8:15 am
Lakes-that's the headset remover, not the crown race remover, different tool for a different job. He wants one to pull the crown race off the forks.
Posted : 05/07/2010 8:17 am
 Roo
looks very similar to this [url= http://www.machinemart.co.uk/shop/product/details/cht226-bearing-separator ]link[/url], can't remember which size you need, so don't go clicking buy without checking.
Posted : 05/07/2010 8:35 am
Mleh, unless you plan on changing crown races every couple of weeks, I can't see how it'd earn it's keep.
big blunt flat headed screwdriver, rag, soft faced mallet, gently tappity-tap around the edge, takes 2 minutes.
Posted : 05/07/2010 8:43 am
All I ever used for the last 12 years. And before someone says 'you'll damage the race' - I never have.
Posted : 05/07/2010 8:49 am
 gamo
Screwdriver has always worked for me too. But I suppose you need some level of mechanical sympathy and thought to operate it, which not everyone has.
Posted : 05/07/2010 9:27 am
 Gnnr
I use this one, even cheaper than Ebay:
http://www.manchestertools.co.uk/hilka-bearing-separator-small-p-31470.html
Works a treat.
Posted : 05/07/2010 11:30 am
Gnnr - is that the very one you have? £3.31 seems ridiculously cheap!
Roo - Liking the look of that one, cheers.
Posted : 05/07/2010 11:55 am
that one from manchester tools is £3.31 but its £5.50 postage
Posted : 05/07/2010 12:08 pm
bearing splitter is a good call
Posted : 05/07/2010 12:09 pm
Group order on those £3.31 ones ?
Put me down
J.
Posted : 05/07/2010 12:11 pm
 DT78
Been meaning to get hold of one of these for a while.
How exactly do they work? Tighten under the crown race and then hit with a big hammer?
Posted : 05/07/2010 12:34 pm
Never bothered - after a while bough decent headsets with split crown races - solves the problem 🙂
Edit: but for that price seems good value 🙂
Posted : 05/07/2010 12:35 pm
dt - they appear to be wedges - tighten them an it forces the wedge under the race
Posted : 05/07/2010 12:38 pm
i posted a similar question recently and someone recommended getting a stanley blade and tapping it under the crown race to get a small gap
then i used something similar to the wedge one above and it worked a treat. i used it along with a 'puller' similar to removing car brake discs
why don't more manufacturers just put a little notch somewhere to get it started? i had some Marzocchis with this and it made life much easier
Posted : 05/07/2010 1:07 pm
Screw driver has always worked fine for me too.
If your race isn't split, just hacksaw a slot into it. Et volia, split race, no more issues. Even donme it to my CK race, works just fine.
They're just bikes, not space planes.
Posted : 05/07/2010 1:11 pm
you just keep evenly tightening the nuts up, and the wedge part of the splitter goes between the parts to be split
Posted : 05/07/2010 1:39 pm
