Crown Race removal....
[Closed] Crown Race removal..
What do you use?
Big, gert, Flat head screwdriver?
Or what? ๐Ÿ˜
Posted : 25/01/2011 6:32 am
Spilt crown race. ๐Ÿ˜‰
Posted : 25/01/2011 6:42 am
I use a 1" chisel. Screwdrivers don't have the same contact area
Posted : 25/01/2011 6:59 am
Depends what headset, some have a chamfered lead-in and come off easily with a wide, sharpened screwdriver, others are designed(by complete d**ks)with a squared off edge that will only succumb to ten minutes with a series of Stanley knife blades.There is a special tool for the job, but even they will struggle if they can't get a purchase under the edge.
Posted : 25/01/2011 7:23 am
+++1 for split ring, making my solid ring into split ring with hacksaw. If a Mg crown be very careful with any meatl levers near it. LBS uses a clamp around crown race and then gently taps away at clamp
Posted : 25/01/2011 7:46 am
Use the proper tool and it's a 30 second job.
Posted : 25/01/2011 8:44 am
So can you just hacksaw your standard crown race and it'll still work ok?
Posted : 25/01/2011 9:27 am
Mowgli - Member
I've done that to a few without any problem. I usually don't complete the cut but they still slip on and off ok.
Posted : 25/01/2011 9:29 am
