Crests - how much o...
[Closed] Crests - how much of a beating can they take?
 br
Added.
Run a 2.4 on the front, real nice profile.
Rear is an Ardent 2.25.
Posted : 17/12/2013 9:52 pm
I thought there was a 90kg weight limit on those wheels however the strength of the wheels really depends on the quality of the build , which from Hope wasn't as good as I expected but the real issue here is can you put up with the freewheeling noise , it's a bit of a love it or hate it thing .
Posted : 17/12/2013 9:59 pm
Ianfitz pm me with some photos and a price would you?
Posted : 17/12/2013 10:24 pm
Alright with strong tyres. Need attention to spokes fairly often as the flex and work loose. Depends how you ride.
Posted : 18/12/2013 12:51 am
Im 65kg and Ive run Crest rims on Pro2's on my full suss for a while now. I generally get on with them but have had trouble when Ive run thinner sidewall tyres tubeless on the rear. I have killed two rear Crest rims with big dings , a crack and an irrepairable flat spot on rocky descents in the Highlands when using tubeless Conti rubber queen (non-UST) and HR (non-UST) on rear. I now only use UST rear tubeless tyres on them , keep an eye on the tyre pressure and they are lasting grand. the rims are cetainly not as hardy and ding resistant (IMO) as Mavic 719 or equivalent though.
Posted : 18/12/2013 10:15 am
Very useful thanks all. I'm 77kg and a wheels-on-the-ground type of rider, the most of a pounding they'll get would be Afan/CyB, otherwise only stuff you'll find in Southern forests 🙂
Should be fine then...
Posted : 19/12/2013 10:30 am
You worry far far too much. About everything!
Olympics/Crests/Alpines will be absolutely fine! Podiums would also be absolutely fine, if a little flexier.
Still got my DT240/Alpines.
Posted : 19/12/2013 10:33 am
They were out of shape after the first week of riding, which I put down to the usual new wheel adjustment.
New wheels (if well built) shouldn't really need any adjustment.
true up to a point but a weak rim even well built will still be weak, just less weak than one built badly... From what I've heard and seen, crests are fairly robust for most riders but heavy riders will be outside the weight limit and therefore any warranty plus will potentially need more truing over time.
Posted : 19/12/2013 10:35 am
But what weak rims are actually out there?
There is no weight limit on Crests, only on Hope's 24-hole Pro 3 builds which utilise them.
Posted : 19/12/2013 10:37 am
njee - I know 😕
Hopefully though I've secured some crests on Pro2 Evo's. 8)
Posted : 19/12/2013 10:44 am
Uncanny. It's almost like you've met...
Posted : 19/12/2013 10:57 am
Going back OTish - what is the Iron Cross rim the 700c version of i.e. Alpine or Crest or something else...?
Posted : 19/12/2013 10:59 am
 adsh
I too weigh 77kg and ride down south. I've got 2 pairs of Crests and find them pretty tough for what I do. The only issue I had was rim ding from a slow puncture that took a bit of persuasion to bend back and seal.
Pro 2 Evo with crests, rim tape and valves came in at 1530g with CXrays and brass nipples. Think the same build with DT comps was 1640g. Much as I love the 'better' build I can't tell the difference. I should have spend the money on better hubs (ACs) and used a cheaper spoke like a D light.
Posted : 19/12/2013 11:09 am
I run Crest's on my 29 HT (Solaris) and have dinged the heck out of them in about 3 months. I originally wanted Arch Ex but couldn't easily find them in the country and went for crest instead, wish id held out for the Arch Ex tbh.
Same here - mine came with a free flat-spot from the previous owner. :/
I have to admit - I'm not sold with them. I've had to rebuild the rear wheel (which was a pig - very easy to over-tension, and don't get me started on straight-pull spokes), they seem to flex quite a bit and compared to other 26" UST rims I've used (Mavic 819s and Shimano M776 wheels) are a pig to mount tyres on.
Next time I'm buying regular spokes and proper UST rims, excess weight be damned.
Posted : 20/12/2013 10:38 am
Width is not really a problem ime. I've had 2.35 Dampfs tubeless at low ish pressures on crests and never felt they might roll off. But damfs are a bit of a magic tyre.
But they flex and need regular tuning up , that's all
Posted : 20/12/2013 10:42 am
Crests? Useless as a rear rim, but okay on the front. Arch EX for the rear would be wise.
Posted : 20/12/2013 11:04 am
Irrespective of weight limits of not, a heavier rider is always going to flex component/wheels of any build more than a lighter rider, given the same riding style.
As I alluded to in my post, I found then nice and light, which paradoxically made the bike seem up for more aggro, but sadly they were a bit soft and a bit 'wangy', which is why I think I had to true them all the time. I'd certainly not use them in a 29er wheel build for my weight and riding style.
Posted : 20/12/2013 9:06 pm
Well, they've arrived. Pro2 Evo's on Crests 32 spokes - 1543g on the kitchen scales with Stan's yellow tape.
I'm pleased :).
Seeing as they is the racing wheels, it's now a question of which tubeless tyres to put on them.
Posted : 28/12/2013 12:30 am
You can now read all of the horror stories of getting X tyre on Crest rims 😉
Surely you don't mean tubeless, but tubeless ready.
Personally if it's racing only, I'd recommend Rocket Ron evos front and rear - paper thin, but very light, and great for racing - on one have them at £15 I think too :).
If it's for varied riding, I'd recommend Conti's MK2 front and XK rear. If you want less grip, a Schwalbe NN front and RR rear do the trick in Pacestar compound. If you want a floppy tyre on the rim, Maxxis have tyres too 😉
If you're after a bargain, and a decent tyre for trail riding, I'd recommend the On one Smorgasboard.
Posted : 28/12/2013 1:41 am
 br
[i]Seeing as they is the racing wheels, it's now a question of which tubeless tyres to put on them.[/i]
tbh You can pretty much tubeless-up any tyre. I've current got on my two sets; single-ply Minion, On-One Chunky Monkey, Ardent and Team XR4 - all tubeless using yellow tape.
Posted : 28/12/2013 8:50 am
Page 2 / 2
