crest 29ers for CX ...
[Closed] crest 29ers for CX use (and commuting)
anyone using them?
Looking at this build for a white kinesis crosslight Pro 6.
Crest 29ers white, red nipples, Hope pro 2 hubs (red).
Any idea what pressures i can run in these rims as i want to be able to use thinner road tyres in the summer, I think its 60psi?
Posted : 28/03/2012 10:39 am
 gee
I have some 42mm Schwalbe tyres running at 70psi with tubes on those.
You can't go that high with tubeless, though.
GB
Posted : 28/03/2012 10:42 am
I've run tubeless at 70psi with no problems - Halo rims, stans rim tapes, sealant
Mind you I also blew my tyre off my rim this weekend with one at 70psi... I guess that high pressure just reduces the margins. 60psi seems to be fine - that extra 10 psi seems to cut into the safety margin.
I wouldn't use road tyres on them at high pressure - I have a second set of wheels for my cx for that (which I'm looking to sell as I'm going to get some stans wheels for a more reliable tubeless setup on my CX)
Posted : 28/03/2012 10:47 am
what pressures should road tyres be run at at what pressure for CX tyres?
Posted : 28/03/2012 11:36 am
100 - 120 usually for road (assuming 23-25mm tyres)
CX will be massively dependent on what/how you ride and how heavy you are. I found I needed 85psi with tubes to avoid pinch flats but then I'm heavy and ride rocky trails on my CX.
Posted : 28/03/2012 11:42 am
What's your concept of thinner?
I think there are better choices.
Posted : 28/03/2012 11:53 am
Two sets of wheels is the solution that almost everyone I know who uses their CX for CXing and road riding has eventually gone for...
Posted : 28/03/2012 11:55 am
There's lots of folk using Open Pros which will take a 23mm road tyre and a 35mm CX tyre without any problem.
Posted : 28/03/2012 11:59 am
Not so good for tubeless but yes, otherwise they're a decent choice.
Posted : 28/03/2012 12:00 pm
Why not Stans Alpha's? Wouldn't use them with canti's (or at least not in mud) though, the rim wear indicator is quite shallow so I guess thats where some of the weight went.
Posted : 28/03/2012 12:06 pm
I forgot to say, for disc brake use if that makes any difference?
So it looks like alpha 340s are the better hoice then or open pros?
Posted : 28/03/2012 12:28 pm
+ Lighter and marginaly more aero.
- Not as stiff (maybe less of an issue if using disks as you'll be using more than the bare minimum of spokes) and double the price (~£80 vs ~£40)
Posted : 28/03/2012 1:37 pm
Are you actually going to use them tubeless?
Mavic A317 used to be a great choice for a tubed disc only cx/touring/commute rim but I think they have discontinued them which seems weird given the growth in this sort of bike.
Posted : 28/03/2012 1:46 pm
Haven't built them yet, waiting on the spokes.
Posted : 28/03/2012 1:55 pm
