Creak from Hope Pro...
[Closed] Creak from Hope Pro 2 rear hub???
I'm getting this annoying creak coming from somewhere within my drivetrain whenever I pedal hard up a steep hill in a low gear.
Having inspected/greased most parts of the 9-speed XT drivetrain (I even oiled the spokes at the point of intersection and greased up the QR skewer), I think the noise might stem from the Hope Pro 2 rear hub.
FYI, the hub came with am aluminium freehub body, which is fairly bitten by the sprockets.
They're pretty popular hubs, so I was wondering whether anyone else has experienced a similar problem?
Cheers,
Peter
Posted : 27/05/2015 3:18 pm
I had an annoying creak that I finally traced to my Hope Pro II hub (after removing / regreasing BB, Seat Post and changing suspension bearings).
Changing the freehub bearings got rid of the creak once and for all.
And yes the grooves on the freehub body is a common problem too.
Posted : 27/05/2015 3:57 pm
take it apart and see if the freehub moves on the axle, could be the bearings, not expensive to get them replaced.
Posted : 27/05/2015 3:59 pm
Check the freehub for cracks. It does happen occasionally but hope have always been really good about it.
Posted : 27/05/2015 5:24 pm
It'll be the bearings the cassette body run on. Yank it off clean n regrease should see it good. Had this on mine last month took a while to track it down..
Posted : 27/05/2015 5:25 pm
