C.R.A.P. singlespee...
[Closed] C.R.A.P. singlespeed . . . I want one!
[#311501]
[url= http://www.nsmb.com/page/s/2854/transition-bank/ ][i]Transition has coined this dropout system C.R.A.P which stands for "Custom Rotating Axle Positioning".[/i][/url]
Could it be prone to wheel misalignment? (tho' no more so than with track ends) . .. I want one anyway.
Mmmmm . . .
Yes, I know that one has gears . . .
Posted : 16/02/2009 9:25 pm
 momo
that bike just looks right.
interesting take on adjustable dropouts too
Posted : 16/02/2009 9:27 pm
Pretty ickle bike
Posted : 16/02/2009 9:29 pm
I saw some hollowtech BB shells that done that before, they were in C+ Can't for the life of me remember who done them though
Posted : 16/02/2009 9:30 pm
I do like that, agree with momo looks just right
lovely solution to the problem.
Posted : 16/02/2009 9:31 pm
paulosoxo, looky here - http://www.bushnelltandems.com/articles/eccentricdefined.html
Just an eccentric hub mount isn't it? What happens to the disc alignment?
All you need is this I reckon
Posted : 16/02/2009 9:33 pm
yeah such a neat solution there is more info on sicklines. What bikes you running at the mo mamadirt?
Posted : 16/02/2009 9:39 pm
Still have the Tazer and just built up another BMX - 90s S&M Dirtbike.
Posted : 16/02/2009 9:44 pm
you'll need to saw that mech hanger off for neatness though
Posted : 16/02/2009 9:57 pm
Captain flashheart.
Not an Eccentric BB as such, but a standard BB shell using cups shimano hollowtech type cups, that were adjustable in the same manner as an EBB. So you can use them on any bike
Posted : 16/02/2009 10:01 pm
http://www.trickstuff.de/index.php?p=d116en1
This one infact
Posted : 16/02/2009 10:02 pm
Wolhound Bikes have been building with eccentric rear hub mounts for a while now.
Posted : 16/02/2009 10:03 pm
Definitely RD! [img] [/img]
Posted : 16/02/2009 10:12 pm
Surely that will have an effect on the rotor in the calliper, and it is on such as small arc that the actual amount of adjustment will be a lot less than an ebb?
Posted : 16/02/2009 10:16 pm
Look very nice but I am just dubious of friction lock to resist twisting as you apply pedalling force. Maybe if there was some form of knurling/indexing to provide a lock I'd be more happy.
As for that eccentric BB for Hollowtech II. Pardon my ignorance but how does it work? Do the eccentrics sit on the BB shell and then the bearing houses screw into those instead of the frame? If so doesn't that then push out the bearings and does it in effect result in smaller bearings? How does it fit with the fixed "axle"?
Any drawings anywhere? I just can't see it and I've got something of an engineering/technical background so not a total knob!
Can't work that b/b out either - is it just for a USA BMX shell?
Posted : 16/02/2009 10:24 pm
It says standard frames and hollowtech cranks. I assume you install those instead of the shimno cups, then rotate to suit
The cup in bits on the left seems all pretty obvious to be fair
Posted : 16/02/2009 10:29 pm
Those eccentric BB's don't give enough throw to tension the chain in all chainring/cog/chainstay length combos, you might need a 1/2 link too.
Or so I've heard.
Can't see the transition design giving enough adjustment either.
Posted : 17/02/2009 12:43 am
MAMADIRT: STEP AWAY FROM THE KEYBOARD, AND MOUSE HOVERING OVER THE 'BUY' BUTTON ON THE TINY BIKE WEBSITE....
I think Mama should get an MBE or something, for Services To Tiny Bikes.
Tiny bikes do look the Budgie's Knickers, though; much better than big gates ridden bt long people.
Posted : 17/02/2009 12:51 am
Yep the eccentric shells thread into a standard BB shell and then the bearings are pressed into them. They work with a 24mm through axle chainset ie HT2 type. If there are stubs to bolt a granny ring onto the chainset they need to be ground off as they will clash with the eccentric shells.
Indeed you might have to use a half link depending on your gear ratio.
I have just fitted one to my old hardtail. Very impressed so far after a couple of rides. I did mention they are expensive didn't I?
Posted : 17/02/2009 1:38 am
more expensive than an eno rear hub?
Posted : 17/02/2009 9:13 am
This is still the neatest solution IMHO, chain tension adjustment in 30 seconds and the caliper always stays aligned with the disc.
[img] http://images.fotopic.net/?iid=ywykit&outx=600&quality=70 [/img]
Posted : 17/02/2009 9:35 am
149 Euros for the Eccentriker BB + 15 Euros for the tool to fit it.
Posted : 17/02/2009 10:28 am
Or this one -
http://forwardcomponents.blogspot.com/2008/12/eccentric-bottom-bracket-patent.html
The Exzentriker works well but with the current Euro exchange rate it's damn expensive. The Forward Components version might work out cheaper?
Posted : 17/02/2009 10:57 am
can see it now. As noted above it can't give as much forward/backward adjust as a genuine eccentric BB but it is after all a compromise STD frame mod.
Still worried about bearing size. Back in ISIS territory?
Posted : 17/02/2009 11:11 am
