Cranks - 175mm or 1...
[Closed] Cranks - 175mm or 170mm on a race hardtail
 Alek
What would be the benefit (if any) using a shorter crank on a race hardtail?
Looking at new cranks for my Soda.
Are XTR worth the extra cash? (currently running 175mm Raceface Deus/Acros ceramic BB)
[i][u]keeping the BB BTW as its superb[/u][/i]
Posted : 06/08/2009 8:15 pm
Why would there be any benefit?
Shorter people sometimes like shorter cranks. Not like you're going to need extra ground clearance in an xc race is it really?
Its a personal preference thing most the time
Posted : 06/08/2009 9:39 pm
 Alek
Was on a web-site for roadies (yes I'm a darksider too) and there was a chart for your inside leg/preferred crank length.
So got me thinking there might be a similar set-up for MTB's.
Obviously not. So i'll stick with 175's.
Posted : 06/08/2009 10:50 pm
the crank size thing does apply to mtb but less so tbh ...
if you are changing anyway then its worth getting the correct size cranks for your leg length - if you email me ill forward you the email that someone sent me with a pretty good fit calc in it - i used it on my bikes - some comfy and some not so .... the comfy ones matched the fit calc pretty much spot on - the uncomfy ones now fit the fit calc and are comfy .....
Posted : 06/08/2009 10:58 pm
Highpath engineering have a calculator on their website[url= http://www.highpath.net/cycles/notes/03.html ]here[/url]
Supposedly more accurate than one based on inside leg measurement.
Posted : 06/08/2009 11:01 pm
"Supposedly more accurate than one based on inside leg measurement. "
"However some '10 speed' cranks place their chainrings slightly closer together, but this isn't critical."
yet they put stuff like that on their website ....
from first hand experiance - if you stick a shimano ultegra 10 speed set up on a 9 speed ultegra chainset - the chain will on its way from outer to inner ring stick between the two rings ..
Posted : 06/08/2009 11:06 pm
[[b]from first hand experiance[/b] - if you stick a shimano ultegra 10 speed set up on a 9 speed ultegra chainset - the chain will on its way from outer to inner ring stick between the two rings]
So you didn't know any better either then trail_rat ๐Ÿ™‚
I did say supposedly. Anyway I'd agree that it is much less critical on an mtb where your moving around on the bike a lot but I have felt a benefit of moving to 165mm cranks when riding on long road sections.
Posted : 07/08/2009 12:04 am
nah was a convert customer who had bought a custom bike else where coming to us to solve a long standing problem he had..... ground down the tabs to make the rings sit just over a mm closer and it solved the problem - que happy clappy customer !
Posted : 07/08/2009 12:07 am
