Cranking up the adv...
[Closed] Cranking up the advice generator
Hi STW, I need some crank advice. My current crankset is a Race Face Ride on a Race Face Bb92 bottom bracket. The cranks arms feel a little flex and I'm looking to upgrade to a lighter, stiffer crank (either XT or XTR).
Could I just slot a Shimano crankset straight into the BB92 bottom bracket or will I need some sort of adapter? I've tried scouring the web and I think the answer is yes but there are so many options and standards that I'm feeling a little baffled. Thought you might be able to confirm.
Thanks!
Posted : 22/04/2016 1:59 pm
This [url= http://www.pinkbike.com/news/to-the-point-bottom-brackets-2014.html ]from Pinkbike[/url] implies BB92 is compatible with Shimano,see about third paragraph down.
Posted : 22/04/2016 2:12 pm
 adsh
Raceface spindle 30mm
Shimano spindle 24mm
Adaptor(s) required I think
Posted : 22/04/2016 3:51 pm
Raceface Ride is unlikely to be 30mm. It'll be 24mm, like Shimano.
Posted : 22/04/2016 6:05 pm
You can replace your ride cranks with anything 'normal' shimano (ie XT/XTR)
Posted : 22/04/2016 6:21 pm
Do they really flex or is it all in your mind / just wanting shiny things?
Posted : 22/04/2016 8:05 pm
