Crank too close on ...
[Closed] Crank too close on Kona Process
[#7354041]
Hi all
My non drive side/left crack is very close to the swing arm.
[URL= http://imagizer.imageshack.us/v2/150x100q90/661/tvMSQ8.jp g" target="_blank">http://imagizer.imageshack.us/v2/150x100q90/661/tvMSQ8.jp g"/> [/IMG][/URL]
Can I simply use a BB Spacer to move it out, or will that cause the crank to be to tight against the bearing. The cranks feel seated correctly I.e. No side ways movement at the moment.
Posted : 27/09/2015 11:27 am
Don't see why you can't fit a spacer.
Posted : 27/09/2015 11:37 am
Can't quite see what cranks they are, but a spacer will take up axle space, so the crank won't bear on the axle properly, may all go solid when you tighten the crank.
I'd be looking at why it's like that.
Posted : 27/09/2015 11:40 am
How close does the drive crank sit? If it's further out you might try switching the spacers to even out the gaps.
And clean your bike.
Posted : 27/09/2015 11:59 am
Press fit innit. No spacers to swap?
Posted : 27/09/2015 12:15 pm
I would say if its all original equipment and you haven't changed anything don't worry about it, my chain is about one squillianth of a millimetre from my chainstay by cassette and its never been an issue, the 'engineers' are paid to sweat the details!
Posted : 27/09/2015 12:32 pm
I just refitted a Shimano press fit with spacer on 'wrong' side, to solve a front mech (bolt on) shifting problem. The crank is now close to stay, but chain line and shifting are spot on...
Posted : 27/09/2015 3:37 pm
That does look a bit too close for comfort. Cranks (and chainstays for that matter) do flex a significant amount under load. It's probably fine but I'd at the very least try and see what another Process with the same crankset looks like.
It may be that the splines on your crank are machined a bit deep so the crank sits closer to the inside than it usually would.
Posted : 27/09/2015 4:43 pm
What cranks are they? Google the q factor of cranks.
I had this problem on my kinesis tripster with some rival cranks. They didn't touch when I built it but they would when under pressure. I swopped them for some xt cranks.
I think xt has a 168 q factor??? From memory.
But just remember that changing your cranks can affect your chain line.
Have the cranks scored the frame? If they haven't I wouldn't worry about it.
Posted : 27/09/2015 6:18 pm
my 153, with slx cranks has a bit more clearance
the bank end is very wide and stiff, I cant see that deflecting much, but the stock sram cranks mine came with did flex a bit, never enough to contact the chainstay though
if theres no marks on either, i wouldnt worry
Posted : 27/09/2015 6:40 pm
Thanks for the responses and yes the bike needs a clean :). Pic was taken after getting back from Surrey Hills.
The cranks are: [url= http://www.chainreactioncycles.com/race-face-ride-narrow-wide-single-chainset/rp-prod113370 ]cranks[/url]
They have nicked the rear arm slightly which is anoyying
Posted : 28/09/2015 1:34 pm
