Cramping fingers/ha...
[Closed] Cramping fingers/hands whilst descending
I've had this issue a while, but only comes on after a significant amount of descending- for example usually at the end of a final descent at a Welsh trail centre.
Basically my index fingers are one finger braking and the other 3 fingers are around the bars- these start to cramp up after a while which is pretty painful. I know this is expected in the Alps(I've experienced it there too!) but in Wales its seems none of the other riders I ride with have it?
I've swapped thing around in my set up recently(majorly!)
New Gloves and a new bike (full sus compared to previous HT) which has different brakes which are run closer to bars, and have different grips too)
I know there are the Ergon grips but I think they are for nerves in palm of hand...any other solutions? A mate recommended doing free weights to strengthen grip, but I'm not sure. Maybe fatter/thinner grips(I have XL glove size-so quite large hands)
I know I could either deal with/get used to it or Rule 5 each time I go to Wales but it sort of ruins a trail when you can't go 100% because my hands hurt. I'm a frequent rider-and longer ride times are usual than when I am in wales.
Posted : 22/02/2012 10:36 pm
Sounds like death grip.
Loosen your grip on the bars (hold on just enough so that you don't let go).
Posted : 22/02/2012 10:47 pm
 br
Carbon bars will put less 'vibes' through.
Posted : 22/02/2012 10:48 pm
Tried loosening my grip last time(as I thought that might be the issue,maybe I did it too late and my hands were knackered by then)- Guess will try harder next time!
Posted : 22/02/2012 10:51 pm
I used to get agonising pain in my fingers whilst descending rough trails, just as you describe. I started using one of [url= http://www.motogriptrainer.com/ ]these[/url] to strengthen my forearms, and it stopped happening. I use the green one, easiest, cos I'm not trying to haul an MX bike about. I do have to use it regularly (two or three sets of 60 or 70 on each arm two or three times a week) or it starts coming back.
Posted : 22/02/2012 10:57 pm
angle of the brake levers / bars? Try rotate both back towards you a bit or just try experimenting with them
But death grip is the most likely - maybe to harsh a fork stetting / too much compression / too hard a spring?
Posted : 22/02/2012 11:03 pm
 Crag
Roll your brake levers back?
I get the same thing if i havn't been to wales for a while, the more you do it the less it affects you.
Posted : 23/02/2012 10:32 pm
Line your brake levers up so that your hand/arm/wrist is in a straight line. I'd recommend the OID Troy Lee grips
Posted : 23/02/2012 10:37 pm
Thanks Chaps, plenty to think about!
Posted : 23/02/2012 10:54 pm
anything but this ime
Posted : 23/02/2012 10:55 pm
try skinny grips (nukeproof worked for me) and could probably benefit from building fore arm muscles up if your not doing such descents on a regular route.
Posted : 23/02/2012 10:59 pm
thomthumb - Member
Everyone's different, I guess - I used suffer until I did that.
Posted : 23/02/2012 11:57 pm
Most likely gripping to hard or you are leaning over on the bars too much, more rise on bars, seat forward a bit so you unweight etc.
Trick I was taught mx'ing was to take hands off in turn and quickly stretch out and clench/unclench rapidly to get the blood pumping to ease the cramp. Obviously this is easier said than done.
Posted : 24/02/2012 12:08 am
death grip or possibly carpel tunnel problems.
Possible things to try:
Try adjusting levers to change your wrist angle
Lock on grips if you don't have some and don't grip so tight
Larger grips (I use ODI rogue as they are large and very grippy so I don't have to hold on so tight)
wrist support or maybe a tennis elbow strap thingy - I had a lot of pain in both my elbow and my fingers (and dead hands) when riding and playing badminton. Larger grips and a simple strap which push on the muscle just below the elbow really helped with all of it. Some pain is not caused directly by a problem in the area you are feeling it.
Posted : 24/02/2012 12:16 am
this, sounds like its just fitness. a powerball might help you build grip stamina.
Posted : 24/02/2012 1:35 am
