Couple of wheelbuil...
[Closed] Couple of wheelbuilding questions
Firstly:
Radial laced front wheel, Try as I might I can only seem to get either even tension or the wheel true. Every other wheel i've built has always been true to within 2mm or so after adding the tension using a gauge. This one just won't go. I've got it straight but the tensions everywhere from 80-130kgf, mostly it's even around 110-120 where I want it, but there's a few places where it goes out (not noticeable on the ping test or my hand, but obvious with a gauge).
Secondly
2x lacing the rear, over under or over over?
hashtag# should have stuck to three cross and not tried to be clever.
Posted : 28/08/2012 9:27 pm
