Could some one be s...
[Closed] Could some one be so kind to check my spoke length calculations? Cheers.
I realize this is a bit stupid to ask, but if anyone could spare the time, it would be greatly appreciated.
[b][u]Rims (Halo SAS 26");[/u][/b]
E.D.R. 538mm
Weight 780g
[u][b]Hub Hope Pro Evo 2 Single Speed 32h;[/b][/u]
SPOKE PCD LEFT SIDE 56mm
SPOKE PCD RIGHT SIDE 54mm
LEFT OFFSET 32.5
RIGHT OFFSET 32.5
SPOKE HOLE DIAMETER 2.6mm
32h
Weight 361g
3 Lace Cross Over
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=12628 ]Spokes DT Swiss[/url]
14mm nipple
I did it on DT Swiss spoke calculator and got 260mm, but can you double check?
Posted : 18/05/2012 8:17 pm
Sorry i'm on my phone but the wheel pro spoke calculator is pretty good pop your numbers into that and compare
Posted : 18/05/2012 8:49 pm
same ERD as 717 so 262/264 works on pre-disc shimano hub (from experience), perhaps a wee bit shorter for your hope.
Posted : 18/05/2012 8:52 pm
 Andy
Wheelpro says 260. Is the ERD, pcd and offset the manufacturers stated or have you measured for yourself? You probably know this anyway, it is best to measure for yourself. Oh and I probably have some 260 DT swiss spokes if needed.
Posted : 19/05/2012 6:54 am
...manufacturers stated or have you measured for yourself?
I looked at Hopes' PDF on the PCD and Offset.
Cool, what model are they?
Posted : 19/05/2012 11:10 am
