Could frost have do...
[Closed] Could frost have done this ? SS rear cassette.
Got up for my daily commute this morning..bright and breezy at 5.30am, a sprinkling of frost and a definite nip in the air.
Went to jump on my Specialized Langster and zilch drive through the rear cassette, ie just slipping.
Had to drive in - brought the bike with me. Just checked the bike and all is ok??
Anyone else experienced this or should I be changing the cassette.
Slightly worried that it could suddenly go like that.
Posted : 06/12/2012 6:47 pm
sounds like the pawls froze
take a leak on it and itll free right off - temporarily :d
quite a common issue at strathpuffer !
Posted : 06/12/2012 6:49 pm
the pawls of the freehub could have frozen in place, thus not springing back so not engaging drive when you pedal. try pissing on it. ๐Ÿ™‚
edit - to repeat excellent earlier advice ๐Ÿ˜†
Posted : 06/12/2012 6:50 pm
 ski
Mine did that today as well, cup of water no pee sorted it ๐Ÿ˜‰
Posted : 06/12/2012 6:51 pm
Hey hello ski...did you get my emither?
Posted : 06/12/2012 6:52 pm
Aye...Frozen pawls.
Ah great so nothing to worry about then ?
Posted : 06/12/2012 6:53 pm
not really. but run it fixed anyway, then it won't happen again. ๐Ÿ™‚
Posted : 06/12/2012 6:54 pm
Anyone got a diagram of what is actually occurring with the pawls etc...
This should be fun 8)
You know how freewheels work?
Imagine it not working.....thats what happens.
Posted : 06/12/2012 6:57 pm
Ah clearer now!
Posted : 06/12/2012 7:00 pm
Posted : 06/12/2012 7:15 pm
Unlikely frozen, more likely the grease is just going a bit too stickey to let pawls spring back - or even just too much grease.
Posted : 06/12/2012 7:23 pm
Same thing happened to my SS last weekend.
It was the grease that had gone sticky. Put too much in after a recent rebuild.
Cleaned it . Problem gone away.
Posted : 06/12/2012 8:29 pm
People often put too much grease in freewheel pawls - and just as often put in too viscous a grease as well.
Strip it, clean it out, and put a smear of lightweight/flowy grease such as Prep M in it.
Posted : 06/12/2012 8:48 pm
Strip and rebuild advised anyway because if it is too thick or gone you will get problems.
Didn't chris king hubs have this problem so they now have a winter grease (or oil?)
Posted : 06/12/2012 8:52 pm
I've had the ratchet ring of a pro2 fill with ice and go smooth, so although the Paul's were moving, they couldn't engage.
Posted : 06/12/2012 9:22 pm
