Cotic Soul (Medium)...
[Closed] Cotic Soul (Medium) with a 75mm stem - ok for someone 5'9"?
Thinking of getting a Cotic Soul and fitting a 140mm Revelation to use as a general trail bike. Will be fitted with a 75mm stem.
I'm 5'9" so am on the boundary between a small and medium. Tempted to go medium as i don't want to be cramped and it will be used for 'normal' riding rather than jumps and stuff. ๐Ÿ˜€
Does this sound ok or should i go small?
Thanks everyone
Posted : 11/05/2010 3:09 pm
I had the same dilema only on the next size up; borderline medium/large. I spoke to Cy about it as well as a few people on here. Cy (and everyone else I should add) was very helpful and it seems as though you can get him on the phone reasonably easily for advice.
I ended up with a medium. Well I say ended up with, what I mean is I've ordered a medium although it's not here as yet so I can't even confirm I made the right decision! ๐Ÿ˜
Posted : 11/05/2010 3:38 pm
I am 5"10" (11" at a push) and after speaking to Cy have gone for a medium too, going for a 90mm stem with straight seatpost and going to see what happens, they are quite long looking at the dimensions so the large would be a bit reach i think even for me, waiting for mine too.....
Posted : 11/05/2010 3:41 pm
5'11'' here on a medium with 70mm stem and 140mm revs. Reach and controllability are all good. very chuckable with the 70mm stem - used to have 90mm which was more of a stretch. Have a Thomson layback post
Posted : 11/05/2010 3:44 pm
 JonR
Sounds to me that barring any freakish body shape like tiny arms or a really long toro then that size should be bang on for what you want.
Posted : 11/05/2010 3:45 pm
6'2 with a medium bfe and 65mm stem. I do use mine for dirt jumps and downhill but its fine for xc stuff so you should be ok
Posted : 11/05/2010 3:47 pm
 lrd
5'7" with a 30" inseam and I've got the small. Fits and rides beautifully with a 90mm stem and seat all the way back on an inline post. In other words, I just about get away with it. As you're a bit bigger, I reckon you should go medium.
90mm stem handles well with 100mm fork, if I wanted to spoil the ride and stick a bigger fork on, I'd probably want a shorter stem and the medium frame.
Posted : 11/05/2010 3:56 pm
I spent ages trying to decide. I am 5 8" so right on the crossover of small to medium. I went with a medium in the end running 130 uturn revs which mainly are left at around 120.
Was it the right choice? well yes and no. I am an old roadie so like a longer top tube, I can say my Soul with a 90mm 10 degree stem feels fine, I wouldn't want it any shorter ( i am using an inline seat post). On the other hand the standover is on the edge for my height.
So what I really need is a small for standover and a medium for top tube so some compromise had to be accepted.
It really depends what you prefer but I would have thought a medium may be best if you don't like things too cramped in the top tube.
Posted : 11/05/2010 3:58 pm
Should be fine, I'm 5'10 and take a medium but I make it look a bit small tbh. Lots of seatpost on show. Stems are a matter of taste, mine is 60mm and works a charm though climbing can need a wee bit more attention than it did when I ran a 75mm.
Posted : 11/05/2010 4:00 pm
5'10", medium, 70mm stem, SPOT ON.
Posted : 11/05/2010 4:01 pm
Thanks everyone, medium it is then!
(Opens up IE and gets Cotic website up ready to call Cy...)
Posted : 11/05/2010 4:07 pm
ok one more:
5-9, 31 inseam, med & 75mm fine - would have gone larger rather than smaller for more stretch
Posted : 11/05/2010 4:45 pm
5'9" here. went with a medium as i run a more xc setup and wanted plenty of room. ran a 90mm stem, tried a 100 for stretch, but going back to a 90mm as i couldn't tell much difference in stretch but the 90 felt better through singletrack etc...
Posted : 11/05/2010 7:23 pm
I'm also 5'9" with a medium Soul and have run various stem lengths from 75 to 90 depending on the forks that are fitted. Fit for me has been spot on.
Posted : 11/05/2010 8:04 pm
if you can get one, I've heard they have sold out of the new back before they have even put them into stock!
Posted : 11/05/2010 8:24 pm
