Converting solid re...
[Closed] Converting solid rear axle to qr - possible?
4 Users
Morning all,
Having just picked up the first puncture on my new single speeder and not having an axle nut spanner with me I was wondering if it was possible to swap out the solid axle on a hub for a hollow QR one?
The hubs are Joytech discs.
Thanks!
Posted : 22/08/2016 7:32 am
 br
Wouldn't it be just easier to carry a spanner?
Posted : 22/08/2016 7:37 am
You can get qr ready hollow axles - basically just rod threaded at each end with a hole through the middle. Take the hub apart first to check it is just a straight-through threaded rod type of axle arrangement. Rear would be 10mm dia, front might be 9mm. QR skewer hole is always 5mm AFAIK.
Posted : 22/08/2016 7:43 am
@b r - probably, but I don't trust myself not to forget it sometime!
@greyspoke - ah cool, I'll have a poke about and see if I can find some - thanks!
Posted : 22/08/2016 8:03 am
I drilled 2 holes into a spanner to fit onto the bottle cage bolts, a coupla rubber washed to protect the frame, screwtop bolts and it sits there ready for whenever I need it (remember to remove and grease the threads occasionally).
Posted : 22/08/2016 10:02 am
