Conti tyres: how fa...
[Closed] Conti tyres: how far below the silly recommended pressure do you run yours?
Trail king 2.4, apex sidewalls, 1kg tyre (in 29 at least), recommended pressure... 50psi? Max 65.
Schwalbe equivalent would be the Hans Dampf Super Gravity, rated 23-50psi. Admittedly slightly heavier.
Across the board though, conti recommended pressures are ridiculously high for trail riding. In the case above, what's the point of apex sidewalls if you're not running them low enough to need pinch protection?
So does anyone know why they recommend such high pressures? And how low do you run yours?
Posted : 22/07/2015 11:45 am
I tend to run between 20-30 psi depending on conditions. Rubber Queen/Trail King in 26 and 27.5 going back several years now. They would be really shite at 50 psi thats for sure.
Posted : 22/07/2015 12:09 pm
22-3 front and 2ish rear MK2 2.4 27.5. Great all rounder.
Posted : 22/07/2015 12:11 pm
I see one of their sponsored riders runs 27/28 psi:
http://www.redbull.com/uk/en/bike/stories/1331672370190/dan-atherton-enduro-bike-check-setup
It's truly bizarre, I can only assume it's a legal thing due to the greater risk of tyres coming off the wheel at lower pressures.
I run low 20s front, mid 20s rear on Conti Protections/UST. I'll drop another 25% when it's really greasy.
Posted : 22/07/2015 12:51 pm
Apologies for the slight tangent/hi-jack, 'sideshow', could you tell me where you got those tyres from, can't find the 2.4 in a 29'er anywhere?
Posted : 22/07/2015 12:54 pm
I'm not sure I can either. Is this it? doesn't mention black chili - really hard to tell!
http://www.highonbikes.com/wheels-tyres/tyres-mtb/continental-trail-king-29-mtb-tyre-folding.html?gclid=CIDUo8La7sYCFQHkwgod-_MHmw
Posted : 22/07/2015 1:13 pm
The Mountain King on the front of my Inbred recommends 50psi, but I normally have it around 30psi. I should probably try it one day at 50psi just to see what it is like, but I suspect it will be rubbish.
Posted : 22/07/2015 1:24 pm
