Conti tyre set up.
[Closed] Conti tyre set up.
I'm thinking of running a 2.4 X king on the front and a 2.2 on the back, is this madness or should I go for 2 X 2.2 (front and rear.
Any thoughts?
Thanks
Posted : 23/01/2014 10:35 am
That's fine, I do the same.
Make sure you get the protection version, the standard conti tyres seem to puncture all the time.
Posted : 23/01/2014 10:39 am
 nikk
The 2.4 come up narrower than 2.4.
I run 2.4 both ends on a hardtail, works well.
Posted : 23/01/2014 10:53 am
It's the mountain kings that are narrow. X-king is a different casing. I'd say 2,4 is too much for an XC/allround tire. Adds quite a bit of unnecessary weight as well. If I needed something more grippy for the front I'd look at either MK or RQ/TK. If you choose the MK however take into account that they are narrower.
Posted : 23/01/2014 11:48 am
I currently run 2.4 front and 2.2 rear RQ Black Chilli and they are teh orsumz.
Posted : 23/01/2014 11:56 am
Thanks all,
Yeah, I've got the Protection versions, bought a Mountain King in supersonic form, but think it's too lightweight.
It's a Yeti 575 and my main bike, so should work out fine.
Thanks for the advice!
Good riding, hope it perks up a bit weather wise too!
Posted : 23/01/2014 12:03 pm
 Yak
Not madness - that's fine.
Even nicer with a 2.2 race king on the back. A bit more volume and a touch faster and ensures the back has less grip than the front.
Posted : 23/01/2014 12:04 pm
 nikk
[quote=toronte]It's the mountain kings that are narrow.
No, the X-king Contis come up narrow as well, and it depends of the exact version you get:
X-King Racesport 2.4 29er - 2.310" wide, 2.225" high (from rim edge)
X-King Protection 2.4 29er - 2.205" wide, 2.137" high (from rim edge).
Mountain King II Protection 2.4 29er - 2.275" wide, 2.228" (from rim edge).
All latest versions, all measured by myself.
60 grams extra wight per tyre. I prefer the extra volume and grip.
MK is 100 grams more per tyre. TK is 300 grams more per tyre. And both are slower rolling than the XK. However, I wouldn't recommend the XK for this weather, better MK for general use IMHO this time of year.
Posted : 23/01/2014 12:29 pm
