Conti Race 28 700c ...
Conti Race 28 700c wide 60mm - where to buy ?
Punctured last night, used my last tube which is a Cont race 700c wide , which I think is 25-32mm
These ones
i can’t find them anywhere now!?
What’s a good alternative?
Ta
Posted : 18/06/2024 8:59 pm
Bump 🙂
Posted : 19/06/2024 10:29 am
Halfords have them in stock you can order online.
Posted : 19/06/2024 10:40 am
Nope I checked - no store or home delivery stock 🙁
Posted : 19/06/2024 10:49 am
 cp
Continental R28 Training Presta Long Valve Inner Tube - Black, 700C x 25-32 C/60 mm https://amzn.eu/d/2EMiF9S
Spendy though
I tend to use decathlon tubes on non tubeless applications
https://www.decathlon.co.uk/p/700x23-32-bike-inner-tube-60mm-valve-presta/_/R-p-306878
Posted : 19/06/2024 10:56 am
The Cycle Clinic appear to have them available to order online. Price is fair as well.
Posted : 19/06/2024 11:06 am
If anyone is remotely interested, I got some on Amazon from Wolf Cycles - 5 for £28 which works out very cheap!
Posted : 02/07/2024 12:55 pm
If you genuinely need 60mm valve. I highly recommend putting some cheap valve extensions in your saddlebag.
Then you can use any tube you can scavenge.
Posted : 02/07/2024 12:58 pm
Never thought about doing that , and such a simple solution !
Posted : 02/07/2024 1:03 pm
Depends if the core is removable! Not all extenders fit all tubes, you need the right combo
Posted : 02/07/2024 1:11 pm
Worth checking sure but I've neither seen extenders that NEED the core removed nor valves without removable cores for about 20 years.
Posted : 02/07/2024 1:31 pm
