Contact lenses-OK f...
[Closed] Contact lenses-OK for mtb?
[#1799975]
Fed up with all the misting up & peering through sweat splattered specs , has any one tried contact lenes off road & if so which would they recommend,TA!
Posted : 14/07/2010 9:26 pm
I have for the last 6 years or so.
They're very good, I used to use focus dailies but found they would blow out of my eyes occasionally. I've now switched to day soft which, whilst being a third of the price, stay in my eyes much better. The flip side is they're more of a nuisance to put in.
It's very rare I go out without them now.
www.daysoftlenses.com
Posted : 14/07/2010 9:31 pm
I used to use daily disposables for MTBing and now use the ones you can leave in for up to a month (not that I do!). Both were absolutely fine, even in manky conditions like tonight.
Posted : 14/07/2010 9:32 pm
I wear focus dailies and have never had a problem with them coming out when riding. Speak to your optician, they will probably know what is best for you.
Posted : 14/07/2010 9:33 pm
 rs
I wear contacts all the time but still always wear sunglasses to stop mud and bugs going in my eyes.
Posted : 14/07/2010 9:34 pm
I nearly always wear protective glasses as well.
I've only had grit get in my eye once on a ride with lenses in. I was using daily disposables so just chucked that lens away and continued on. Seeing out of one eye is enough at the speeds I ride!
Posted : 14/07/2010 9:36 pm
Over a decade using them, no worries here. I currently use daily disposables and always seem to have a surplus so can take spares out, but I can't recall ever having to use a spare. I guess you should take something to clean your hands if they are covered in shite before shoving them in your eyes, I've never bothered, but you probably should.
yeh i have them, been fine, i normally wear sunglasses/clear lenses to stop anything going in my eyes
Posted : 14/07/2010 9:37 pm
Great , thanks for the advise & encouragement , I will see my optician next week.
Posted : 14/07/2010 9:45 pm
I have been using monthly disposables since last november and I love them. Never had a problem losing them whilst riding but if the weather turns nasty a pair of clear specs helps. When I was fitted they measured all aspects of my eye to make sure I had the best possible lenses for me. Well worth looking into it.
Posted : 14/07/2010 9:46 pm
fine but wear glasses as the grit is anoying and take glasses just in case you loose lenses.
Posted : 14/07/2010 9:49 pm
use them all the time have done for past 20 years or so.
9/10 times ride with clear glasses to stop grit/shite getting in my eyes.
as above carry a couple of spare lenses and hand wipes incase I loose one (never have) as I'm blind as a bat without ocular assistance 😯
Posted : 14/07/2010 9:50 pm
I've worn gas pemeable hard lenses for 30 odd years which are great for vision but I did suffer quite a lot with grit getting in them. I was practiced enough though that I could readily pop it out and rinse it in my mouth and back in with no real probs.
Until: about 8 weeks ago I was suggested to trial daily disposables instead of replacing my GP's. I don't think the vision is quite as good (I can still see an ant at 20 yards, but with GP's I could see the ant's pubes at 20 yds) - but by heck I haven't had any problems with grit or dust since including 2 very dusty races.
Recommended.
Posted : 14/07/2010 10:21 pm
I prefer daily disposables - easy and cheap to get rid of if there's a problem and pretty comfy too. I always wear glasses with them though for protection. Highly recommended!
Posted : 14/07/2010 10:24 pm
I usually wear glasses, only really wear contacts for gigs and mountain biking... Sometimes I wear protective glasses but in summer I prefer not to (cold wind in winter makes my eyes tear up constantly) and never had any real bother with mud- no more than people without contacts seem to have anyway. Love 'em.
Posted : 14/07/2010 10:36 pm
Monthly disposables here for years - no problems with riding. Always wear glasses with interchangeable lenses (dark, yellow, clear) which covers all eventualities. I would ride with glasses for protection even if I had perfect eyesight.
Posted : 14/07/2010 10:37 pm
I went to see about prescription sunnies for the bike; optician in the village (who is a very nice chap, as well as a consistent Top 10 finisher on the Three Peaks Cyclocross) recommended contacts + normal sunnies - this has worked very well indeed, apart from the occasional tendency for one lens to fall out on long cobbled descents.
Andy
Posted : 14/07/2010 10:57 pm
I use Focus Dailies and have done so for many years with no problems.
I keep a spare pack in the glovebox of my car in case I lose one while riding (never happened so far) and have to drive home.
Posted : 15/07/2010 4:08 am
I've used yearly's, monthly's, and daily's - all worked fine. Worth taking a spare pair just in case something weird happens.
Wearing shades is also helpful because it keeps (99% of the) crap out of your eyes - a muddy/sticky lense and muddy/sticky fingers isn't good.
Posted : 15/07/2010 9:25 am
I did for 10 years then did the sensible thing and had laser surgery. Best thing i've ever done
Posted : 15/07/2010 9:58 am
I used to, thought they were fine but got mud in behind them every now and again even with protective glasses on - Ouch - had laser surgery done a few years ago and think its brilliant.
Posted : 15/07/2010 10:01 am
 tron
I wear contacts, but I always wear some cycling glasses over the top when I'm riding. If you get muck in your eye with contacts, it's more painful than without.
On the other hand, when I rode with normal glasses, they tend to fall off, don't cover enough of your eye, and you end up cleaning the lenses of something that cost > £100 with a muddy bit of jersey.
Posted : 15/07/2010 10:12 am
Same for me [single use type ] -on mtb or road bike. But always wear cycling specs to keep mud and flies out. I find normal glasses bounce around too much when descending.
Posted : 15/07/2010 10:21 am
20 years use, I use the two weekly types. I don't wear additional eye protection and have only one example of grit getting under the lens ( painful !)Usually the muck comes out after a couple of blinks. But I found fire roads and tarmac the worse terrain for spray in the eyes.
Posted : 15/07/2010 12:57 pm
Been mtbing with contacts for 15 years now - monthly disposeables. When I first started, I did sometimes get dry eyes after cycling but the more recent lenses are much better (higher water content IIRC) and I have no problems. I do almost always wear glasses (dark/clear as necessary) though to stop mud getting in my eyes.
Posted : 15/07/2010 12:59 pm
Am on Focus Dailies now but was monthly disposables in the past. Have been using them for 15 years or so.
As others say, I always ride with protective specs of some sort (clear Bolle safety specs in winter or at night) just because mud/grit in your eyes is hard to clear without losing the lens.
Posted : 15/07/2010 1:04 pm
